Valve Clearences for a Lister D?
Hi there!
Is it true that the valve clearence/Tappets for a Lister D is set at .31 thou?
Thanks
Thanks
Wolseley WD2+H2 Pump
Bamford EG1
Petter M and 110v Dynamo
Lister D
Petter AA1
Statman- Life Member
Re: Valve Clearences for a Lister D?
That's correct Adam, 31 thou. Might have to bend your feeler guage though!
Pete
Pete
someone told me it works out if you get it so there is no gap then unscrew both adjusters 5/8ths of a turn on the thread and it is 31 thou.
just got this off a manual i downloaded from IF, its a snipet of the lister D manual including a note regarding valve cleanances.
0.003" or 3 thou when engine is hot methinks.
» Valve timing Lister D
» Lister d valve settings?
» Lister A valve guides
» Lister LR1 valve springs
» Lister "D" valve guides
