Lister D 1Hp with Wrong flywheel
Hi Guys!!
Bit of a silly question really!!
I know of a Lister D 1Hp 500Rpm working and everything but i was told by a forum member and also a friend of mine they have a 14" Flywheel but this one has got a standard 12" flywheel also they S/N's dont match
Does it really matter that it has different flywheels
Thanks
Thanks
Wolseley WD2+H2 Pump
Bamford EG1
Petter M and 110v Dynamo
Lister D
Petter AA1
Statman- Life Member
Re: Lister D 1Hp with Wrong flywheel
It all depends on you or whoever buys it!
I would guess that due to having a smaller flywheel it would have ever so slightly less torque. (Probably Minimal)
I thought you didnt want it though! What you like
Lister John- A credit to the forum
its okay mr Ross you can mention my name in your threads hehehehehe
the only time it will matter is if the engine runs lumpy, and if the engine year, spec and parts dont match, which in a serious collector, would be cause for some nagging, and probably result in an engine rebuild.
you need to check what parts should be fitted to your engine against the spec list, which you can get from "the lister D story" by D. W. Edgington, or from stationary engine . net
» Small flywheel for Lister D
» lister d flywheel
» Lister D flywheel
» Lister CS6 flywheel wobbles
» lister d flywheel
» Lister D flywheel
