Soldering fuel pipes
Post by RAB on Wed Dec 23 2009, 04:50
hi folks,i need to solder a fuel pipe, will a normal wire heating iron do the trick Very Happy
Re: Soldering fuel pipes
Post by Guest on Wed Dec 23 2009, 08:21
will do it you can get it hot enough
Post by Guest on Wed Dec 23 2009, 10:25
try using a simple butane blowtorch, that'll give you much more heat and avoid a dry joint.
nice one thanks chaps
Post by RAB on Wed Dec 23 2009, 14:20
will have ago Very Happy
