copper head gaskets
copper head gaskets
Post by RAB on Fri Jan 01 2010, 19:24
hi all just trying to find out some things, were can i get copper sheets from to make a gasket, and what do they use in the centre of a double copper gasket is it some kind of foam, also how is the gasket stuck to the foam, any help would be most appreciated as im at a bit of a dead end her at the minute Very Happy
Re: copper head gaskets
Post by Guest on Fri Jan 01 2010, 20:06
isnt the head gasket made like a sandwich? eg copper what evers in the middle the copper, then punched out?
quote from Wiki
Composite -- an older technology. Typically these are made from asbestos or graphite but are more prone to blowouts than newer gaskets. Asbestos gaskets are becoming increasingly rare due to health concerns.[2]
i had one for a D
Post by RAB on Fri Jan 01 2010, 20:11
it was a layer of copper at the top and one at the bottom, but something black in the middle ??????? ideas Very Happy
Post by Guest on Fri Jan 01 2010, 20:15
if it was black/grey i would say graphite, dont go snorting it either way lol!
Post by Guest on Fri Jan 01 2010, 20:17
hmm dark blue/balck could be Asbestos, whats it for?
it was for a dk
Post by RAB on Fri Jan 01 2010, 20:19
but it looked like foam, it was brand new recently so would not have been asbestose, anymore ideas Very Happy
Post by Guest on Fri Jan 01 2010, 20:26
ah its new Rolling Eyes should have said Laughing
Post by Guest on Sat Jan 02 2010, 21:58
modern stuff is compressive gasket material, the copper helps to keep it all together under the duress of its duties, the material is a modern composite, probably containing things like silica/silicon (glass) and other high temperature fibres.
Paul Smile
