oil drippers
oil drippers
Post by RAB on Sat Jan 16 2010, 19:13
hi all what oil should you put in oil drippers, is it just normal sae30, thanks Very Happy
Re: oil drippers
Post by Guest on Sat Jan 16 2010, 19:49
Yea should be fine
CHeers Steve
good cause thats what
Post by RAB on Sat Jan 16 2010, 20:13
ive just stuck in it lol
Re: oil drippers
Post by Hope and Crank on Sat Jan 16 2010, 20:18
You might want to dribble some oil across the skirt of the piston, or leave the oiler on for a while before starting - often it takes a while for the oil to get to the piston, and after standing for a while it's likely to be quite dry.
And of course make sure it is working!! May sound daft, but it's easy to raise the lever and assume that it is, but it might be blocked or incorrectly set!!
Can't beat a good crank - I have one every day...
Hope and Crank
yeah done all that
Post by RAB on Sat Jan 16 2010, 21:08
the old fibre washers were knackard so will replace them , cheers
Re: oil drippers
Post by Foden on Sat Jan 16 2010, 21:17
About 6 - 8 drips per minute if I remember correctly for the piston oiler Ryan.
thanks chaps
Post by RAB on Sat Jan 16 2010, 21:22
ive decided to go back to it all next weekend, as if im honest im a little lost, this is my first open crank, so need to find out lots before even trying to start it Very Happy
Re: oil drippers
