Cooling tank?
Cooling tank?
Woundering what to use as a cooling tank if i get this Stuart R3 bit stuck on what to use, as its got a pump i could just use a bucket, but i want something a bit better looking.
Been toying with the idea of old fire extinguishers
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&Item=350305892990&Category=9903&_trkparms=algo%3DLVI%26its%3DI%26otn%3D2
think it should work but how effective at cooling they are is another thing.
extinguisher cooling tank
Hi steve,
I have a similar cooling question I am asking myself. That is for a water cooled compressor. For the Stuart your fire extinguisher cylinder would I guess work as long as it was of sufficient volume to suit the engine.I would just use my own judgement here.The guess for my compressor would be for an 11kg gas bottle with the top cut of and a loosely fitting lid. Chris.
Sir Clip- Expert
Re: Cooling tank?
Sir Clip wrote:Hi steve,
Yea should think it would be alright will hold 2 gallon, i wouldnt know about the compressor.
Re: Cooling tank?
general rule is, you want your cooling system to be small enough so that under whatever load you intend to put on it, you can get the water to boiling point, if you have too much cooling area, the engine will stay cold, hence why off load lister CS's can use small propane cylinders as cooling rather than 45 gallon drums, it gets them hot and prevents bore glazing.
a small exinguisher should be spot on for the stuart, if it boils, just top it up, will be nice and steamy lol.
P.
P.
Re: Cooling tank?
I'll empty one for you...
Can't beat a good crank - I have one every day...
Hope and Crank- A credit to the forum
Fittlings?
Bit stuck on how the pipes would connect to the tank? not sure sure if i can get my hand into the tank.
Any ideas?
Any ideas?
Re: Cooling tank?
Skankin_giant wrote:Bit stuck on how the pipes would connect to the tank? not sure sure if i can get my hand into the tank.
Any ideas?
you may have to silver solder the fittings on? or rivet (old style ) a plate on
Re: Cooling tank?
Yea that's what I was thinking. think I could solder it used to doing components so plumbing should be a new venture.
if worst comes to worst theres always JB weld!
Cheers steve
Cheers steve
Re: Cooling tank?
Skankin_giant wrote:Yea that's what I was thinking. think I could solder it used to doing components so plumbing should be a new venture.
Cheers steve
prepare it right and you'll have no problems with silver solder, much stronger than ordinary solder
Re: Cooling tank?
I might end up sacking this cooling tank idea off lol, getting to much time i add the soldering stuff up, will have to see if i can get a rectangle trough type thing me thinks!
cooling tank.
i made a box section cooling tank from plate steel, welded steel tube top and bottom about 2" in length and used car cooling pipe to connect the tank to the engine. this was cheap and i will never need to make another.
earl.
earl.
earlsinclare- Life Member
» stuart turner project.
» Petter M 5hp victory model water cooling tank
» 1924 wade drag saw.
» Lister D cooling tank - size?
» Remove cooling fan ring Villiers Mk15
