Ruston Pb Ignition probs
Hi Chaps!
Today i gave my PB6 a short run and it started absolutly fine no bother what so ever but the other day it was a swine to start.
Anyway id stopped the engine for a short while and started it again bugger wouldnt go so i belted it up to Johns little engine.....Any how it started up fine after that!
Then it ran out of fuel so i refilled and it wouldnt go unless you cranked hard then that didnt work so checked for a spark and nout or a little tiny one
Is this a condensor problem or a coil problem?
Thanks
Thanks
Wolseley WD2+H2 Pump
Bamford EG1
Petter M and 110v Dynamo
Lister D
Petter AA1
Statman- Life Member
Re: Ruston Pb Ignition probs
More then likely the coil. one for the WX11 was like £12.
Hi Steve!
Yeh from what i heard from enquiring about it most likely the coil!
Luckily i rung up Kerwin and he will supply a new coil for £30 which im chuffed about also i will change the condensor for a safe measure!
Bamford EG1
Lister D
Petter AA1
Hi Chaps!
Just got back from seeing Kerwins
The coil gave a fab reading the condensor was fine and the earthing was excellent too!
So we didnt know what was wrong we began to think about the magnatism but then i said about the points Kerwin said OH YEH! So he cleaned the points and the gap was out quite a bit so when it was sorted we checked the spark and hey presto fat blue spark and she was now a runner!
Best thing is it cost nout!!
Bamford EG1
Lister D
Petter AA1
» Ruston Hornsby pb6. magneto coil.
» Ignition Help!!!
» BSA F15 ignition problems.
» More Ignition Experiments
» Ignition timing
» Ignition Help!!!
» Ignition timing
