wd that has no spark at plug
wd that has no spark at plug Empty wd that has no spark at plug
Post by fourshoes10 Sun Mar 07 2010, 18:00
Got a WD,which had a couple of years as other chap could not get to to run,no find there is no spark can turn it and hold the spark plug and not get the normal poke off it.Now i know nothing about magnetos any help be nice.
fourshoes10
wd that has no spark at plug Empty Re: wd that has no spark at plug
Post by kernowjohn Sun Mar 07 2010, 18:13
try cleaning the points with some emmery paper
kernowjohn
kernowjohn
Post by fourshoes10 Sun Mar 07 2010, 19:18
Done that,still no spark Mad
fourshoes10
Post by Hughesy Sun Mar 07 2010, 21:55
make sure the bottom point isnt earthing on the magneto i had it with mine.
theres a thin piece of metal runnning off of it place a piece if plastice / tape etc under it to stop it shorting before reaching the plug
lewis
Post by fourshoes10 Mon Mar 08 2010, 17:46
The piece of plastic is in place,above all that is a brass effect tube is that the condenser,if so the 2 screws that hold it in place are missing,it does move slightly would this cause the no spark problem
fourshoes10
Post by Statman Mon Mar 08 2010, 17:52
Are the points opening and closing??
Also are you getting any reading from the coil?
If any other questions give this guy a ring for info
Kerwin Harris
01872273388
Thanks
Wolseley WD2+H2 Pump
Bamford EG1
Petter M and 110v Dynamo
Lister D
Petter AA1
Post by Hughesy Mon Mar 08 2010, 18:24
there should be 2 screws in the and a lead under one of the screws. lewis
Post by fourshoes10 Mon Mar 08 2010, 21:32
Hopefully sorted now,cleaned HT lead ends,can now get a poke off it when turned,so fingers crossed can get engine running tomorrow Smile
fourshoes10
Post by Guest Mon Mar 08 2010, 22:44
Im getting a simular problem, can get a whack of the lead, but a weak spark when testing the lead against the casing, put a plug on it i get a spark but vanishes after a bit.
starting to get annoyed with it! may use battery coil if i get anymore annoyed Very Happy
Post by fourshoes10 Tue Mar 09 2010, 20:11
Mad Put mag back on engine turn it and nothing,no spark or poke of HT lead,run out of answers
fourshoes10
Post by Hughesy Tue Mar 09 2010, 20:22
its earthing out on something.
check it all over and make sure its nothing small stopping it
lewis
Post by fourshoes10 Tue Mar 09 2010, 21:01
Any idea what i should be looking for
fourshoes10
Post by Guest Tue Mar 09 2010, 21:13
If your getting a poke from the HT lead, check the plug is not buggered.
Even new ones can be U/S, If you know anyone with a runner see if you can borrow there plug to see if that cures the problem.
Best of luck
