made a trip to the Multi-Coloured Swap Shop! (Stuart P4y)
and swapped my R3 for a P4y
Cheers, Steve
Cheers, Steve
Re: made a trip to the Multi-Coloured Swap Shop! (Stuart P4y)
Loveley!!
Where did you find that too?
Does she run?
Does she run?
Wolseley WD2+H2 Pump
Bamford EG1
Petter M and 110v Dynamo
Lister D
Petter AA1
Statman- Life Member
Boat forums are good for stuarts
not tried it yet, mag may be a little iffy but i prefure these to the R3 so swapped was only 90mins down the road
Ah ryt!
Well it looks really nice!!
Im still after a Petter M but still aint decided which one to go for and need money too lol
I can get a 5hp Petter M Victory lol
Bamford EG1
Lister D
Petter AA1
Statman wrote:Ah ryt!
Im going to give it a coat of paint and clean the carb up a bit, will see if i can find a dynamo for it, its alot heavier though!
Its not just buying a petter its running the thing! my 1 1/2 running very slow would burn a gallon a day! the bigger they get the more they burn! plus you will need a sturdy trailor for a Victory model, i like the Appletops dont see many small ones, normaly 3hp and above.
she will be put back to the orginal shade of green dont like it as is, need to fix my hand 1st
» a bit of a swap.
» A SWAP for something with a bit more HP
» Lister CS piston swap
» a trip to bradford.
» Timing a trip mag
» Timing a trip mag
