Stuart Turner P4y Light Restoration
Post by Guest on Tue Mar 09 2010, 00:04
After i get the magneto working all it should need is a paint job, cooling and fuel tank sorting.
got the magneto drive cover off as i was taking the magneto off.
Re: Stuart Turner P4y Light Restoration
Post by Guest on Thu Mar 11 2010, 12:51
well got some parts from Green Spark Plug Company, Will try and rebuild the mag as soon as i get this cast off! might try left handed lol
Post by Guest on Sat Mar 13 2010, 15:48
Had a go at painting a little bit today, but couldnt do to much, cant control the left hand where i want it to go Sad ,
will see what i can do when i get back from Marrakesh cheers
Fizz Bang!
Post by Guest on Tue Mar 23 2010, 14:54
got the mag working! new points and ht lead and all was good lol
and could resist this:
as you can see not quite right, only a quick run as havnt got cooling etc yet!
excuse the paint and video work, I think i done well, I have got a broken right hand! lol:
Post by Guest on Tue Mar 23 2010, 19:42
youtube is being a pain so heres the direct links
https://www.youtube.com/watch?v=l9ApMpQzV4A
https://www.youtube.com/watch?v=mpqyXkbxZEI
Post by Guest on Wed Mar 24 2010, 16:37
Had a little play at lunch, she starts 1st pull no issue, just back fires and free wheels to a stop, i think its firing just after the ignition mark so will need to adjust the timing a little to get it right!
Post by Guest on Wed Mar 24 2010, 17:55
Had a though on the way home from work!
the exhaust may be to longs and not clearing the expansion chamber, and causing exhaust gasses no to exit the cylinder!?
Well i took the pipe of and the results are to follow.
Post by Guest on Wed Mar 24 2010, 21:13
So from the videos im thinking of cutting the exhaust pipe down a bit, and read the manual on running the engine from front to cover!
http://www.stationaryengineforum.net/videos-f27/stuart-p4y-2nd-run-t1819.htm
Post by Guest on Thu Mar 25 2010, 13:25
well i have took about a foot and a half off the pipe and its much better!
just need to adjust the governor/throttle control so that it shuts off the throttle a bit more as it revving its nuts off at full throttle! think its set up for running a dynamo still.
ByJov I think I FINALLY got it
Post by Guest on Thu Mar 25 2010, 17:44
Think im just about there with it, she starts easy and thumps away nicely! think i might be happy lol
Just uploading a video may take a while!
Post by Guest on Thu Mar 25 2010, 20:08
Videos up!
http://www.stationaryengineforum.net/videos-f27/stuart-p4y-im-now-happy-i-think-t1823.htm
Post by Guest on Thu Apr 01 2010, 08:55
Well now i know it runs i took the carb and exhaust off to paint the engine,
while cleaing the carb i found a bit of a repair job
so instead of having a polished brass carb i might paint it and keep the float top, choke and a few key bits brass, not sure if i should do it green or black? any ideas?
Getting there
Post by Guest on Sat Apr 03 2010, 11:37
Getting there, just need a few things to sort out a cooling tank.
Post by Statman on Sat Apr 03 2010, 16:09
Hi Steve!!
That looks brilliant!!
I havent forgotton about the fuel tank just aint had the chance to remove it lol!
Ill try and remove it on monday
Wolseley WD2+H2 Pump
Bamford EG1
Petter M and 110v Dynamo
Lister D
Petter AA1
Post by Guest on Sat Apr 03 2010, 16:12
No Worries Adam,
I got one that will do for testing got a few to many dents to use it for show.
Cooling check!
Post by Guest on Sun Apr 04 2010, 13:28
got a tank set up, tempoary petrol tank next.
Post by Statman on Sun Apr 04 2010, 20:22
Very nice tank!!
One question.....When the tank is full of water in time do you think the pipes will sag?
Bamford EG1
Lister D
Petter AA1
Post by Guest on Sun Apr 04 2010, 20:30
well i was worried at 1st,
but i tested it with my battery drill, and 2 litres of oil in it, and i pushed down on it a bit and it seems fine, im going to build a plinth at some point but seems ok until my hands sorted.
CHeers Steve
Post by Statman on Sun Apr 04 2010, 20:38
Im off tommorow i will remove that tank!
I insist that its ok for you to have it
I will take a picture for you again
Bamford EG1
Lister D
Petter AA1
Post by Lister John on Sun Apr 04 2010, 20:55
That looks a nice little engine! reminds me of a petter M a bit.
Lister John
Post by Guest on Sun Apr 04 2010, 21:26
Hi Adam do you get my pm?
I did just have a idea of how I could fit it
Post by Guest on Tue Apr 13 2010, 15:36
Yay new float arrived today, hopefully will sort it out and touch up some paint.
