Lucas N1 timing help
Think the Stuarts bad running is down to the timing, its firing just after the ignition mark.
Its there away i can change the timing with out undoing the sprocket and turning the shaft around? Looks like the movement in the points is for fine adjustment.
» ruston & hornsbt pb6 timing
» mk 10 timing
» lucas mag help
» wolseley timing
» Hard to start Ruston PT
» mk 10 timing
» lucas mag help
» wolseley timing
