Lucas N1 timing help
Lucas N1 timing help Empty Lucas N1 timing help
Post by Guest Wed Mar 24 2010, 16:35
Think the Stuarts bad running is down to the timing, its firing just after the ignition mark.
Its there away i can change the timing with out undoing the sprocket and turning the shaft around? Looks like the movement in the points is for fine adjustment.
