Petter a Range
Petter a Range
Post by WildPikey on Mon Mar 29 2010, 15:59
Just wondered if anyone can tell me the difference between a Petter a and a Petter as?
WildPikey
Re: Petter a Range
Post by Statman on Mon Mar 29 2010, 16:16
Im not 100% sure but to my knowledge the AS is a higher revving engine for the army
Thanks
Wolseley WD2+H2 Pump
Bamford EG1
Petter M and 110v Dynamo
Lister D
Petter AA1
Petter a Range
Post by WildPikey on Mon Mar 29 2010, 17:30
Thanks for the reply,That does make sense as it is marked war department.
WildPikey
Re: Petter a Range
Post by jay on Tue Mar 30 2010, 07:53
not always..
A petter AS is the higher powered usually from 3hp to 6hp and has a double the thickness flywheel of a petter A also sometimes has a extended shaft on the starting handle side for another pulley take off...Someone on here has one in a saw bench that dont look ex army..I got a factory water pump set on a cast bed plate in light blue with a petter AS 6hp petrol parrafin engine on it..all matching numbers..
jay
Re: Petter a Range
