Norman S/C
Norman S/C Empty Norman S/C
Post by Guest Sun Apr 11 2010, 19:04
well why i wait do decide what to do woth the stuart, i decided to look over the Norman
started getting it apart and removing the old paint, been a while since it was last gone over.
Norman S/C Empty Re: Norman S/C
Post by Guest Mon Apr 12 2010, 11:41
Raf Blue it is then, well RAF Blue Grey to be correct BS633
should end up this colour, but satin
Norman S/C Empty got the flywheel off!
Post by Guest Tue Apr 13 2010, 22:01
got the flywheel off! She looks like a old bike engine!
Wire brush aint touching the paint, i knew i should have bought some stipper while i was down BnQ!
Norman S/C Empty Broke out the paint
Post by Guest Fri Apr 16 2010, 19:40
decided to try the new paint, this is only the 1st coat to top coat so will need a rub down and another few coats, its had 3 coats of primer/undercoat.
i like the new colour! this paints much nicer to paint then the stuart green i have.
Post by Guest Sat Apr 17 2010, 17:49
Bit more painting, i like this blue cant wait to build it up!
Post by Guest Mon Apr 19 2010, 19:57
Getting
well, little bit stuck on a few bits but the grey matter is getting there,
I shall be giving it another rub down and a few more coats, and cleaing up the bright work.
will see if i still got some white modeling paint for the lettering.
Post by Admin Mon Apr 19 2010, 20:49
Thats looking great, nice colour will be nice mounted.
Post by Guest Mon Apr 19 2010, 21:18
Thanks, im liking the RAF blue grey Very Happy
Post by Statman Mon Apr 19 2010, 22:24
Thats looking some smart Steve!!
Wont be long now till you fire her up!
I hope it does well for you
Wolseley WD2+H2 Pump
Bamford EG1
Petter M and 110v Dynamo
Lister D
Petter AA1
Post by Guest Tue Apr 20 2010, 14:51
Statman wrote:Thats looking some smart Steve!!
Cheers Adam
Its only loosely assembled there for the photo, need to regrind the valves and all 1st, need to remember how the throttle/governor control went!
did have a show planed for the weekend but might give it a miss and spend time with the wife!
Post by Guest Sun May 02 2010, 17:08
Well she's running again Very Happy
had to put the old pulley on to start it, so looking a bit out of place, but she running!! need to work out the trottle control as that still aint right!
got a bit of paint to touch up etc, and a noticed i had a bit of a oil leak when taking this pic!
Post by JONESEY Sun May 02 2010, 21:39
Looking good Steve, I like the finish on it
Jonesey Smile
Post by Guest Mon May 03 2010, 18:30
Cheers!
I didnt think a Armed Forces engine should be Gloss so went for Satin, glad people like it! it was a risky choice
Post by Guest Mon May 03 2010, 20:24
Whats silencer do people think will go with this? would a WD type one look right?
the diameter is approx 28mm isd and 32mm osd
Post by JONESEY Mon May 03 2010, 20:56
Something thats not to noisey, small flexie pipe with car silencer on. They used strange things Neutral
Post by Guest Mon May 03 2010, 21:08
Yea its getting hold of flexy exhausts, in that diameter.
Post by JONESEY Mon May 03 2010, 21:46
Try Bell Silencers in Swindon or Any Motor Factors. There used to be a great little shop in Chippenham on the one way sistem opposit the cinama mixes paint alsorts he might be worth a try
Post by Admin Tue May 04 2010, 19:18
Skankin_giant wrote:Yea its getting hold of flexy exhausts, in that diameter.
I tried to get flexi pipe not so long ago and it was expensive.
Try your local garage they may have a small bit kiking about that you may get cheap.
Post by Guest Tue May 04 2010, 19:25
Iv got hold of a wd type exhaust think it will look ok!
Post by Admin Tue May 04 2010, 19:28
Yea should look ok.
Post by Guest Fri May 07 2010, 22:46
still waiting on the Silencer and Pulley,
But it is starting on the Handle now!!! 1st time in 16yrs!!!! well pleased and with a broke hand 2 cheers
Post by mike d Sun May 30 2010, 22:30
HI STEVE.....
thats looks very nice....
you have been bizzy getting the engine sorted...
you should be proud of it.....
thanks for posting the progress of the rebuild
keep up the good work....
regards......mike.
Post by Guest Sun May 30 2010, 22:34
Thanks, she's pretty much finished, il shall get a finished pic up!
Post by mike d Sun May 30 2010, 22:47
looks fine to me.....
keep it up.....
once again thanks for posting the photos....
regards.....mike.
Post by Guest Sun May 30 2010, 22:51
I shall get some up of my new toy at some point Very Happy
Dosnt need much doing to it though, just been sat for 3 years,
