play time in dorset......
HI ALL...
it was play time in dorset today....
just finished the pump,gave it a complete strip down and rebuild+paint.. so good excuse to get an engine out and test the pump...
works well
[url=https://servimg.com/view/14348076/71][/url]
works well
Re: play time in dorset......
That looks a great set up.
I thought I could here a Deere John running
Now I now were I put that tin of green paint
You better come over and get the Yellow tin and paint the pumps fly wheel
hi chris....
thanks for your comment on the pump and engine.....
it a good job my boy was her...if he hadn't have found it the pump would be a shitty green color....
i need to collect the plate as well.....have you a spring for the governor on the john d.....
regards.....mike d.
regards.....mike d.
Good job well done there Mike.
BRASSO- Life Member
I think so come up to the castle and I will find you one, just joking its only a house
BRASSO wrote:Good job well done there Mike.
hi martin....
thanks for your comments.....
regards....mike d.
Looking good mike, i see you remembered how the pipes went this time then, DONT FORGET THAT SPRING, that rubber band will break soon,
ian
ian
ian webb- Life Member
all under control.....
got loads of rubber bands......
mike d.
mike d.
» NEW TOY TO PLAY WITH
» Had a play today
» Nice Day to play
» West Dorset Vintage Rally at 8th - Sun 9th Jun
» Crank bearings
» Had a play today
» Nice Day to play
» Crank bearings
