operation Dynamo.
Page 1 of 2 • Share •
Page 1 of 2 • 1, 2
operation Dynamo.
Thanks to Pugdud i have something ot keep me busy.
I got a bit of work to do! is there any tests i can do with a multi meter before i start getting any further in?
Re: operation Dynamo.
Looks like new inside, that will make that engine work nice
HI STEVE.....
thats the sort of thing i want.....
that will look very nice on the rally field when its finished....
mike.
mike.
SORRY STEVE.....
all sorted now....
sorry.....its my age.....
hows the dynamo coming along
all sorted now....
Well its im getting a voltage from it so just need to put it back together. I got some pics at home.
Well i hooked it up to that Sattley and got a little power from it,
https://www.youtube.com/watch?v=1HAS7b2mATY
I need to try it on the norman really will run it abit faster!
Can anyone advice on what else i could try, the voltage was lower then it should be! unless im measuring it wrong?
Anyone want to swap for a pump or compressor lol
hi steve....
is it better to have a big pulley or a small pulley on the engine you driving it from???
im not sure...
im getting the same amount of power as you are from my tuscan one i have.....
regards......mike.
im not sure...
regards......mike.
Um big to small, as the engine will turn once for several turns of the dynamo,
I think i found out what im doing wrong, will try again today!
Sorted it, i need to connect the feild wire to the positive output!, im getting 18v at tick over on the norman!
I need to get a pulley with a key way though but this one will do for testing!
il get a video up when she cools off
Well its working!
Just need somthing to run off it! would like to save up for a search llight!
Mike, check your field windings, connected mine to the + output and it sorted it!
The sattley wont spin it fast enough on the pulley, will see if i can find a a bigger fan belt and try off the flywheel
Skankin_giant wrote:Um big to small, as the engine will turn once for several turns of the dynamo,
glad i could help steve.....
mike.
Tried the Dynamo out again, will look at tiding it up over the winter. Does anyone else get this issue with photobucket screwing up the photos?
Im getting between 12-16v on tick over on min current, with a bit more speed and the current set to its highest im getting 40+ depening on speed.
will try and think of what to run on it, Im worried that the voltage going up and down like that will blow what bulbs I put on it.
Sorry Mike I think Im going to keep it until I hear more on where im going.
OK...thanks for your reply...
will keep my eyes open for another one for my son....
now i can tell him whats happening...
many thanks....
regards...mike....
many thanks....
regards...mike....
Well I varnished up some wood for a simple base, going to dump the jap mounting base, I dont have a use for it.
Still trying to think of a Lighting display.
I would like to do something like this, but Ohms law says I dont have the power!
Will see what I can do with a few less bulbs!
theres no picture to see????
regards...mike...
regards...mike...
you could use 12/24 volt bulbs to make a board up......
seen lots of them like that,a mate of mine has a 12 volt generator running a load of lights,
he was at ERICS rally this year with the words AMANCO HIRED MAN all lit up,
you must have seen it as you were there...
regards.....mike...
regards.....mike...
Yea seen that, Its showing up on my pc, it is running linux though, yea seen that, I could do it if I ran a could of sets in parallel.
Had a little fiddle about today and it will run just as well in either direction, so that makes me feel better about it.
Great news Steve, keep us informed to your progress and one or 2 pics would be good.
stationary stu- Life Member
Right Little update on the Dynamo, as it was needed to get the scott to run about right.
It has been fitted with a Taper Lock pulley of about 4 inches, I even managed to find the pullet Key
So I was looking for some lights, I was looking at running some bulbs, but checking out the price of bulbs and holders I decide to have a look around ebay, after a few searches I turned up this.
Its a 24v ex military lamp, not sure what off but should give the dynamo something to run!
Next thing to do is to work out how to wire it up!
Nice looking lamp Steve, is it a search light of some kind? or just some type of vehicle spot light, can you see what size bulb fits it?
We have illumination!
https://www.youtube.com/watch?v=IwVlhkGfmSA
Should have it hooked up to the Scott at Henham and IF EOS, well could used something to rest it on!
Steve looks as if you can hook a lot more to that dynamo as the light was very bright and there seemed to be little change to the engine revs. In fact I'd say that it could blow the bulb there's that much power available. What's it like in real life in case I'm not getting the right view n video.
Page 1 of 2 • 1, 2
» Going for a small operation
» A Little Message for Anyone Who Read the Operation Wintergreen Blogs....
» LGB Point/signal motor unit operation
» M1 A2 Abrams 1-35 Tamija Operation Iraqi Freedom
» Vividred Operation anime/manga discussion thread
