metal in the size you want.
i use mallard metals for my steel stock. you can buy just what you need instead of having to buy full sheets or full lengths of rod.
www.mallardmetals.co.uk
hope this helps Earl.
earlsinclare- Life Member
Re: metal in the size you want.
Looks to be a good site Earl and prices aren't to bad, you any idea on the postage as thats what normally spoils a good thing. I tried to download the there brochure to keep on file but it wasn't having it so will have to try later.
i've always found it reasonable. but i suppose it depends on what you order, if its a small item then the postage will seem expensive a larger item it will seem cheaper.
i've always found them very helpful,give them a call he's always willing to talk about what you want.
Earl.
Earl.
» Supplier of metal cut to your specific size
» Metal spraying.
» 1st time metal solderer ...
» Mallard Metal Packs
» Red oxide metal primer
» Metal spraying.
