SPARK PLUGS
Plug supplier with alternative plug reference guide.
Post by stationary stu on Fri Aug 14 2009, 09:06
I found this site I've never used them, but they do have a handy tool set into the site that will give you the alternative plug. e.g. type in the search 8com comes up £15 but no stock, so click on alternative in stock and it gives a list of others you could use Smile so you could then use a Champion D16 @ £3.50 but who says you have to buy from them? use your own supplier if your happy with them as you have alternative numbers you could give them.
http://www.gsparkplug.com/
Re: SPARK PLUGS
Post by davec on Fri Aug 14 2009, 11:57
Did you put a link to the site up that I can't see Stu, or an I being dense?
Dave Smile confused
davec
Re: SPARK PLUGS
Post by stationary stu on Fri Aug 14 2009, 17:27
Sorry Dave I've corrected it now. alien
SPARK PLUGS
Post by BRASSO on Sat Aug 22 2009, 16:42
SPARK PLUGS.CO.UK
Have used this company for buying D16's.
Seem to have everything you would want in spark plugs.
Worth a try.
Re: SPARK PLUGS
