BSP pipe fittings ?
BSP pipe fittings ?
Where is the best place to get some 1/4 BSP to 5/16 copper pipe fittings to make a fuel pipe from?
I have the pipe and flaring tool just need the 2x end nuts.
piston power- Born to be wild
Re: BSP pipe fittings ?
Hi there,
Have you tried your local plumber suppliers, I think theres someone on ebay who sells that type of thing.
Failing that try a Hydraulic/ plant mechanics, they may have something in the bottom of a box somewhere.
Have a look here to see if what you want is here.
http://shop.ebay.co.uk/?_from=R40&_trksid=p3984.m570.l1313&_nkw=BSP+pipe+fittings&_sacat=See-All-Categories
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=BSP%20fittings&cm_mmc=UK-PPC-_-google-_-1_MRO_Spt_Generic_Plumbing-_-BSP%20fittings_Broad
Thanks for those i'll llook when home this work pc won't allow e bay.
Piston power PM me with your address I will send you some
What a nice fellow you are Jonesey!!
BRASSO- Life Member
» Fuel pipe fittings
» Correct fittings size for fuel pipe Lister A
» Pipe work sizes.
» Lister D exhaust pipe
» Maytag flexi pipe
» Pipe work sizes.
» Maytag flexi pipe
