Enfield HO MKIV Barn find
Post by pacemaker500 on Wed Jun 16 2010, 13:23
Found this old engine in Shropshire, looks to be fairly complete but is seized. Has anyone got one of these as i think there is some pipework missing from the exhuast ports to somewhere..?
Need to recover it from broken down barn and wow is it heavy.....
An update on the above, its only 5 odd years...Engine recovered and now un-seized; the problem was flywheel to outer casing corrosion. Its being worked on and will be running soon one hopes.
Last edited by pacemaker500 on Wed Jul 15 2015, 09:31; edited 8 times in total (Reason for editing : update, on the way to getting the engine running)
pacemaker500
Re: Enfield HO MKIV Barn find
Post by Guest on Thu Jun 17 2010, 08:40
That look alright dont it!
heres a few vids of the flat twin ones, might be some use
https://www.youtube.com/watch?v=hnQAvWHIrzM
https://www.youtube.com/watch?v=xxfIzgMeh20
Enfield HO Engines
Post by pacemaker500 on Thu Jun 17 2010, 12:37
Thanks for the pointers Steve.
I have seen the one video but not the other. It would interesting to know what the evolution of these engines are i.e. changes between MK 1 to 4. This engine seems to have the exhuast port at the opposite end of the cylinder head to the starting handle to that shown on the video.
If you look at the 3rd picture and bottom RHS, you can see the RH cylinder exhuast port.. You may also see some pipe work (small bore copper) which enters top of the port (same other side) I guess some sort of sensor, but the commoned end goes somewhere I have yet to identify.
Robert
pacemaker500
