Villiers WX11 WAT
Villiers WX11 WAT
Post by Guest on Mon Jul 26 2010, 19:36
Well decided to make a start on the WX11,
She all seems ok inside nothing major to worry myself about!,
So It should just be a clean and a paint job and she will be grand! The only think I need to get it a Bar to remove the flywheel, the nut is very tight, it is normal thread right?
The piston seems massive for a 1 1/2hp engine,
Re: Villiers WX11 WAT
Post by Guest on Tue Jul 27 2010, 20:12
Well I decided to go out again and give it a rub down and another coat of red oxide, I done the exhaust the other day,
Quick question should i rub down the last coat of primmer before the top coat?
Post by Guest on Wed Jul 28 2010, 17:23
Well my paint didnt turn up Mad
But got the paint for the exhaust base, will give it another coat or so should be ready to make a base on Saturday! As you can see went with black, I like the look of having the base black and the engine a solid colour.
Post by Guest on Thu Jul 29 2010, 20:17
Put it all together to see if it was balanced ok,
So just need to rub it down and stain it, and try and find some cast wheels!
Flywheel Nut.
Post by cruisercol on Sun Aug 01 2010, 22:19
Probably too late for you now, but the flywheel nut is a conventional thread.
i.e. Righty Tighty, Lefty Loosey.
Also flywheel should be on a taper lock bush, no nasty gib head keys to mess about with.
Just undo nut, light tap on flywheel, and ,heypresto it's off. (in theory anyway).
cruisercol
Post by Guest on Mon Aug 02 2010, 07:22
I thought I was, I got the parts manual so I seen the taper lock bits, just the nuts that tight I though I was hitting it the wrong way!
But the nuts going to stay there now, my Tyre bar and mallet wouldn't shift it so not much will! well maybe a Impact wrench but im not forking out for one of them.
Post by Guest on Wed Aug 04 2010, 12:30
Right, As you might be able to tell, Im no good with wood!
So its stained and varnished, shame I didnt see the drips! Embarassed
Still waiting on the paint for the engine! getting annoyed now, I put a coat of the paint I got for a Under coat, so just waiting on the paint really!
Tanks had the pipes soldered in and just need painting and rubber pipe fitted, petrol tanks here and need stripping and some petrol pipe sorting.
Post by Guest on Wed Aug 04 2010, 20:35
So it going to be rubbed down and used as a base coat, the paint better come by the weekend!
part from that I cleaned the paint off the petrol tank, just the fun part for cleaning a brass tank!
Post by Guest on Thu Aug 12 2010, 18:39
Paint came today! so did the fuel connection.
so cracked out the paint in the bit of sun we had today.
Also made the bracket for the fuel tank, and remove the old broked pipe from the fuel pipe nipple, just need to work out the fuel tap size, 2 steps forward one step back!
Post by Guest on Sun Aug 15 2010, 17:04
Well its back together!
But she aint a bad looking hector.
Post by Guest on Mon Aug 16 2010, 20:20
Right she is back together with new petrol pipe, got a few issues, my gasket was rubish and dosnt create a good enough seal! so the cylinder will have to come back off, and I havnt had time to look at the flywheel at the mo. But she ran quite well after adjusting the throttle arm,
Post by mike d on Tue Aug 17 2010, 10:03
hi Steve....
you have to much time on your hands....
you must be quite an expert on these now....
regards..........mike
Post by Guest on Tue Aug 17 2010, 12:42
I like to keep busy, go mental doing nothing, Im no expert! I do like the WX11's though, would like a LZ tank cooled (older Headless type)
Post by mike d on Tue Aug 17 2010, 12:48
will you be making a bigger trolley for the engine....
so that it all together rather than two pieces????
Post by Guest on Tue Aug 17 2010, 12:51
Nah goes in the boot easier this way lol! its been done that way as I dont have a trailer.
Post by mike d on Tue Aug 17 2010, 13:16
good idea mate.....
just come off the phone with someone that CAN ship FROM the states....
i have an email address...i need to send them a zip code(post code) and they can tell me if they can collect and ship it...
they ship container's loads over so it may not be to bad.....
but they are in WALES...so don't know if i would have to go to WALES to collect the engines or what....
will see how it goes...
regards..............mike.
Post by Guest on Tue Aug 17 2010, 13:42
Cool, Wales aint to bad, my Wife's sister lives in Swansea I got a excuses to go that way lol!
Post by Guest on Tue Aug 17 2010, 14:13
Cant find me a Little maytag could you cheap lol!
Let me know how it goes getting stuff back! If I get posted the states I could set up a little side business!
Post by mike d on Tue Aug 17 2010, 15:23
ya....will keep you posted....
will pm you some sites....
mike.........
Post by Guest on Tue Aug 17 2010, 21:01
I may be tempeted to swap/PX for something smaller, not sure yet see how it goes loading/unloading i, I quite like having a tank and hopper cooled, but I havnt really got the room.
Sorry, I think I might be Bi-polar or something?
Post by mike d on Wed Aug 18 2010, 11:44
no worries mate...
regards.....mike.
Post by Guest on Sun Oct 24 2010, 13:17
While the sun was out I thought I would remake the broken gasket.
Post by mike d on Sun Oct 24 2010, 13:35
STEVE...the suns out here,but its bloody cold....
braver man then me..... lol! lol! lol!
mike....
Post by Guest on Sun Oct 24 2010, 13:44
Its not to cold here, working im slipper might have been the wrong choice though lol, only went out to let the dog out lol!
Post by mike d on Sun Oct 24 2010, 13:53
it must be something thats catching....
I'm always going out for a smoke and spending an hour in the shed in my slippers... lol! lol! lol!
then i get a boliking when i come back in... lol! lol! lol!
regards.....mike....
