1938 petter a.
1938 petter a.
Post by earlsinclare on Sat Sep 25 2010, 14:09
this 1938 petter a found its way into my shed when i was out.
it is a runner but i will restore it over the winter along with my a1.
Earl.
earlsinclare
Re: 1938 petter a.
Post by RAB on Sun Sep 26 2010, 08:43
Nice looking engine there,
The flywheel are easier to remove from these engines compaired to the a1.
Ive never been able to remove an a1 flywheel without damaging the thing, but the a type engine seem to come of no probs with a bit of patiance.
I have one of these engines there nice engines.
What is the depth of you sump?
As the a type engine had 2 diffrent size sumps.
Re: 1938 petter a.
Post by earlsinclare on Sun Sep 26 2010, 16:46
its the model with the shorter sump.
earlsinclare
Re: 1938 petter a.
Post by JONESEY on Sun Sep 26 2010, 19:28
Thats you sorted for the winter lol! lol! lol! lol!
Jonesey Very Happy
Re: 1938 petter a.
Post by mike d on Sun Sep 26 2010, 20:34
i don't know...the nerve of some people....
cant even go out with out some one leaving things in your shed....
well done...please keep us posted with the progress....
many thanks....mike....
Re: 1938 petter a.
Post by Guest on Sun Sep 26 2010, 20:54
She aint a bad looking hector! have fun
cheers steve
in bits looking for the noise.
Post by earlsinclare on Thu Sep 30 2010, 16:50
i think i have found the noise, the starting cog on the inside is worn around the shaft, anyone got any ideas on the best way to fix it.
Earl.
earlsinclare
Re: 1938 petter a.
Post by mike d on Thu Sep 30 2010, 22:22
HI EARL...
Steve is your best bet..(skankin giant)....
its his field of expertees....
good luck...
noisy gears.
Post by earlsinclare on Thu Oct 14 2010, 06:22
i found the noise, it was the fixed shaft that the starting gog/gear sits on this has now been repaired ( i knew the lathe would get to do a serious job eventualy). all i need now is a better set of timing gears the set on the engine are very worn and chattery. i've put an add in SE so we will have to wait and see.
Earl.
earlsinclare
Re: 1938 petter a.
Post by Guest on Thu Oct 14 2010, 09:59
mike d wrote:HI EARL...
good luck...
I have a field of expertise? its news to me lol!, I know abit about Normans, and Stuart Turners but thats about it, Laughing
Communications is what im trained in everything from Computers to Radar and sat comms, havnt done any machine work since I sold my Mini lathe.
Re: 1938 petter a.
Post by mike d on Thu Oct 14 2010, 22:42
HI EARL...
looks like you've been busy..glad you found the problem....
theres nothing worse when you cant find the problem....
well done.....
regards.....mike...
Re: 1938 petter a.
