Poor spark condensor problem?
Post by piston power on Tue Oct 12 2010, 11:56
Re built the Lister engine all that there is now is the magneto, Tested this today and the spark is poor at least there is one i was thinking of replacing the condensor as i would have in the old Cortina!
Would you agree and is this under the black cap at the top?
The points may require a little clean and re gap what do you use to clean points electrical cleaner?
I cleaned the the contacts in the black cap with emery cloth so hopefully this made some differance.
piston power
Re: Poor spark condensor problem?
Post by JONESEY on Tue Oct 12 2010, 22:04
I would take the cap off first clean the ends off the coils and the earthing wires.
Try this before you buy a condenser normaly if theres a
spark you can get them to run and they will re magnitise there selfs
Jonesey Smile
Post by piston power on Tue Oct 12 2010, 22:22
Thanks old mate i'll give that a try. Very Happy
piston power
Post by mike d on Wed Oct 13 2010, 21:32
if you get stuck give this fella a pm..
Vintage Magnetos his name is Andrew,he does mags for a living.....
top fella,he can help you...
good luck.....
regards.....mike....
Post by Guest on Thu Jan 06 2011, 12:40
piston power wrote:Re built the Lister engine all that there is now is the magneto, Tested this today and the spark is poor at least there is one i was thinking of replacing the condensor as i would have in the old Cortina!
Aside from speaking to vinatge magnetos, your best course of action is to buy nigel mcburney's Lister D restoration book, that has a detail section on magnetos and how to clean them properly, do that and you should be laughing.
cheers.
Paul Very Happy
Post by mike d on Fri Jan 07 2011, 15:55
you need to speak to Andrew..(vintage magnetos)...
hes spot on for that...
hes done a few for me now and thay are great....
regards.....mike d...
Post by Guest on Fri Jan 07 2011, 18:11
I thought it was a hobby gone wrong lol! he's got a life beyond magnetos.
