Engine identification required - Enfield 250cc flat twin stationary engine
Post by huddm on Sun Feb 13 2011, 21:09
Hi all
Can somebody please help, I've got an Enfield 250cc petral flat twin stationary engine, I would be really interested to find out more about it and what is was originally intended to do?
The name plate says this:
ENFIELD CYCLE Co Ltd.
TYPE 250cc TWIN
ENGINE No.1343
Any information will be much appreciated
huddm
Re: Engine identification required - Enfield 250cc flat twin stationary engine
Post by Guest on Sun Feb 13 2011, 21:57
The enfield engines were used on charging sets for the military, some were used as power generators for Radar post war
Hope that helps
Post by Guest on Mon Feb 14 2011, 12:21
they also built diesels, some singles, some flat twins and some "sloper" singles, for the underside of wagon chassis.
Cheers.
enfield flat twin
Post by kevjhnsn on Thu Apr 14 2011, 03:11
i have a milatary charging set with the flat twin enfield mine is dated 1940 on the mod brass plate riveted to the engine cover
if you need HP or any other details of the engine or geny please PM me for more details i have the manual to it somwere arround ??? SAFE ????
mine is still in its reserve stock stat with the preservitive oil in the engine and the electrics ,plugs, inlet and exhurst sealed up with that wax paper stuff .
and its bloody heavy to lift for two people
even though its got to lift up handles at each end of it
anything else i may be able to help you with please message me
hope this helps you ?????????????
thanks kev
