Identification of Lister Engine
I recently bought a saw bench which is powered by a Lister diesel engine. The engine is in need of some TLC both functionally and cosmetically. When I first took delivery the engine ran well, however now it will not start and it seems to be suffering from a lack of compression suggesting that a valve is stuck open. Before I start to strip the engine I would like to get hold of any maintenance documentation I can. I would also like to get a parts/spares catologue. I have the details of the engine from the flywheel casting and the identification plate, which has a small part missing.
The flywhell number is 20HO208. The identification plate has the following details recorded on it. No. 17/6 SRIA24.... or 1776 SRI24.... THP6 BS649 RPM 1800. The .... is where the ident plate is damaged.
Can anyone help identify this engine please?
Tony
Tony
no frillls- I really need to post more
Identification of Lister engine
In addition to the info I provided earlier here is an image of the engine concerned.
Re: Identification of Lister Engine
Reading between the lines it looks like the 1,776th Lister SR1 built in 1974
Regards - Richard
Regards - Richard
richardhula- Posts : 2
Lister 8/1 made in RSA
Hi guys, help please. I have a 8/1 with the following engine plate;
247 8/1 34
5.97 KW
850 RPM
Made in RSA.
I didn't know that we ever made listers in South Africa
Thanks
Dennis
247 8/1 34
5.97 KW
850 RPM
Made in RSA.
Thanks
Dennis
dennis- I really need to post more
dennis wrote:Hi guys, help please. I have a 8/1 with the following engine plate;
247 8/1 34
5.97 KW
850 RPM
Made in RSA.
Thanks
Dennis
IF it follows on from the numbering system Lister used between 1952 & 1981, it would be the 247th 8/1 built in 1984
Regards - Richard
lister 8/1
Thanks Richard, makes sense, still confused about the "made in RSA on lable
Quite a few countries made Lister’s under License, saves on import duties etc.
Thanks a lot guys
Dennis
Dennis
» Viilers engine identification
» Petters engine identification
» Lister identification help
» Identification 2 cylinder open crank engine
