stuart type N
stuart type N
Post by Guest on Mon Feb 28 2011, 22:06
Hello,
I'm currently awaiting delivery of a Stuart turner type N, I am trying to gather some information of this type
Any information will be gratefully received.
Ps, Mike I'm still intreated in that Bernard.....Very Happy
Re: stuart type N
Post by Guest on Thu Mar 03 2011, 17:08
Tried to get it going today, it will start and then stop, I think there is a little dirt in the tank so going to give it a clean and try it again
Re: stuart type N
Post by JONESEY on Thu Mar 03 2011, 20:05
Looks good, your dogs not inpressed Laughing Laughing Thanks for shareing photos
Re: stuart type N
Post by Guest on Thu Mar 03 2011, 21:41
Thanks for the comment, I might change the water tank as I got a dynamo to fit, plus its going to be painted stuart green
Re: stuart type N
Post by JONESEY on Thu Mar 03 2011, 23:41
Steve is that the propper exhaust it looks great, just like a mini Petter exhaust.
Should sound nice Smile
Re: stuart type N
Post by Guest on Fri Mar 04 2011, 09:52
Yea they normaly have a expansions chamber similar to a P4 one, but this one looks like it belongs all bolt hole etc are right.
Just waiting to see what it sounds like.
Re: stuart type N
Post by Guest on Wed Mar 16 2011, 19:10
Hello
Going to repaint and rejig the cooling tank on the Stuart N.
Her she is at the start.
I have since got it apart and started to strip the old paint, and it seems curiosity killed he cat!
Will see if I decide to fill it in again before painting or not.
Re: stuart type N
Post by JONESEY on Wed Mar 16 2011, 19:58
Tiny or what Smile If your going to fill it use that liqiud metal stuff cant rember what its called but I have a box of the stuff , pm me Steve with your address Steve and I will send you a tube its great
Jonesey Smile
Re: stuart type N
Post by Guest on Wed Mar 16 2011, 20:03
Oh right, It had some pink stuff in it before, was wondering if filler would take the heat.
Il get my address to you asap, let me know how much you want.
Re: stuart type N
Post by JONESEY on Wed Mar 16 2011, 23:51
I have just come in from the workshop, J B Weld its called it's like putty . You cut a piece off the size you want and keep rolling it in your hands like plastercen it gets warm and sticky Smile , then fill the gap or what ever you want to do with it. Give it about 24 hours to go right off and then you can grind it ,drill it.
I will put in the post tommorow I owe you for the DVD you sent me
Jonesey Smile
Re: stuart type N
Post by Guest on Thu Mar 17 2011, 18:26
Cheers Thanks for that, Il have to get a couple more sorted this year.
Right got the base stipped and steam cleaned and repainted, all the black should dry satin.
Re: stuart type N
Post by JONESEY on Thu Mar 17 2011, 20:13
Looking good, are you useing that paint that dosent need under coat Question
Re: stuart type N
Post by Guest on Thu Mar 17 2011, 20:44
Twas undercoated twice yesterday, well the base, flywheel and tank was, didnt think I would need to photo it in boring grey.
Re: stuart type N
Post by JONESEY on Thu Mar 17 2011, 20:46
Ah I was just wundering I keep seeing it be in advertised, I sent you a pkt today
Re: stuart type N
Post by Guest on Thu Mar 17 2011, 20:49
No I picked up the 1st satin black metal paint I seen in B&Q, turned out to be that non-drip tar like stuff, like painting with double cream Very Happy
Nice one, thanks very much, Il remember to take my video camera when I go out and about this year.
Re: stuart type N
Post by JONESEY on Thu Mar 17 2011, 20:53
I have a lot of Engine DVDs if you want to borrow any
Jonesey Smile
Thanks Very Much!
Post by Guest on Fri Mar 18 2011, 10:30
Jonesey the stuff arrived today! thanks very much for that.
From memory it sticks like the preverbal to a blanket, seem to remember the new apprentice have a load spread in his pubes and then tied up in the rafters lol! I got locked in the empty dirty oil container, was a massive thing.
Re: stuart type N
Post by Guest on Mon Mar 21 2011, 13:50
Getting there
Need to get some head gasket material, can anyone recommend any? after the non-asbestos fibre stuff.
Re: stuart type N
Post by Guest on Mon Mar 21 2011, 20:24
did a little more tonight, just to keep me busy Very Happy
I need to find a better way to secure the chain guard.
Just waiting on a few ingnition parts, and some gasket, then the fun job of the cooling tank and fuel, got the out-laws down on my 6 off, so paint should be nice and hard! after that its the dynamo.
Re: stuart type N
Post by JONESEY on Mon Mar 21 2011, 23:14
Looking good Smile Smile Smile
Re: stuart type N
Post by Guest on Tue Mar 22 2011, 19:15
Was quite tempted to sell it to buy that lalley light on ebay, but speaking to the chap it going to be way to heavy, I do fancy the Hartop on there though.
Re: stuart type N
Post by mike d on Tue Mar 22 2011, 19:50
Steve...
have you a spare carb top......
got a fella that's looking for one.....
regards...mike....
Re: stuart type N
Post by Guest on Tue Mar 22 2011, 19:57
For a N...No they are a bespoke carb for the N so other stuart carb parts are not interchangeable , I know where to get one for other models.
Re: stuart type N
Post by mike d on Tue Mar 22 2011, 20:30
Steve...
can you give me the info....
i can pass it on to the fella....
regards.....mike...
Re: stuart type N
Post by Guest on Sat Mar 26 2011, 22:18
Crisis averted! I had to remove the head studs as the previously fitted nuts were the wrong pitch and killed the studs, so removed 2 ok and the other 2 cracked off, one quite deep the other just bellow the surface, both drilled out and re-tapped with ease! they were both beyond the surface so wasnt to hard to drill out the stud 1st with a small drill bit then with a larger, I then run a tap down through and it is taking hold of some clean thread Very Happy.
Ordered some new head studs and nuts, luckily there the same as some exhaust studs, Is it worth fitting them with some loctite?
Re: stuart type N
