Will hammerite do the job?
Post by Tony C on Tue Apr 19 2011, 19:58
I have recently bought a very rusty Villiers mk 12hs (non runner) attached to a Beresford stork pump, have now got it up & running well, so now its time to paint the tinwork etc, from what I can tell it was originally painted blue same as the pump, my question is will hammerite withstand the temperatures?
Cheers Tony.
Tony C
Re: Will hammerite do the job?
Post by RAB on Tue Apr 19 2011, 20:04
Hi Tony,
Cant see why not, just be carefull when you fill the fuel tank though. If you spill petrol on the paint work it may react and blister all your hard work.
Post by Tony C on Tue Apr 19 2011, 20:17
Thanks Rab.
Thanks Paul, I'll give it a go then, the reason I asked was because the engine seems to have been oversprayed with something similar by Beresford when the pump was fitted. Have taken your remark re petrol onboard. Smile
Cheers Tony.
Tony C
Post by RAB on Tue Apr 19 2011, 20:25
Ive seen a lot of smaller engines Painted with Hamerite and as much as the colour looks good for the engine the hamerite finish spoils it.
Have you thought about smoothrit?
It may give a better finish, Its just my view though.
Post by Tony C on Tue Apr 19 2011, 20:32
Good idea Paul, I agree the hammer effect is not very pleasing to the eye.
Cheers Tony. Rolling Eyes
Tony C
Post by Guest on Tue Apr 19 2011, 20:55
The Plasti-kote paint you can get from B&Q is aces! I use there Super Satin on most my projects, withstands petrol etc and is so easy to use. I dumped half a tin of hammerite as it was shite!
Post by mike d on Tue Apr 19 2011, 23:25
Tony C wrote:Thanks Paul, I'll give it a go then, the reason I asked was because the engine seems to have been over sprayed with something similar by Beresford when the pump was fitted. Have taken your remark re petrol on board. Smile
Cheers Tony.
HI TONY....
would it not pay you to get it shot blasted?????
you could then paint it with enamel paint..as it would a cracking finish..
jonesy and i have had a lot shot blasted,and it makes a difference...
its up to you mate....just a thought..
regards...mike...
Post by Guest on Tue Apr 19 2011, 23:29
Shot blasting, all very posh Very Happy
Nitromors and a wire brush does the job, I used a wirebrush drill wheel for speed Very Happy works a treat.
Post by mike d on Tue Apr 19 2011, 23:36
shot blasting is the nuts..
far better paint finish..
regards..mike..
Post by Guest on Tue Apr 19 2011, 23:53
mike d wrote:shot blasting is the nuts..
regards..mike..
Yea if you got the money to spend, I had it done on my francis barnett falcon, also had the wheels power coated yea nice job. I also done my 1st P4 in college in the shot blaster in college
not so sure on the "Far" better finish, with a bit of hard graft and nitromors and a wire brush I can get a engine back to bare metal, with A bit more use of a wire brush I can get the rust and cack off, quick rub with Wet and Dry then a wipe with White spirits, and get it painted from a fresh, red oxide, under coat then paint. Its just as good as any paint job that has been shot blatted before hand, just takes a little more effort then dropping it to the shot blasters lol!
2 Examples to back up my claims
Villiers WX11 done by me in this way, the base is in Satin so wont be as shiny as gloss.
and my Sattley done by the previous owner who taught me how to do the above, he was a coach sprayer by trade.
Post by mike d on Wed Apr 20 2011, 08:00
MONEY....its for peanuts...
the fella jonesy and i use charges £30 to do the whole engine block..
that's inside and out and all the cover plates and head etc....
hardly worth pissing about with...take it to him and collect later on that day....
jobs a gooden.....
regards...mike....
Post by Guest on Wed Apr 20 2011, 10:20
£30 on a engine that might not be worth much more.., £30 Peanuts!? thats a weeks worth of lunch and dinner for me and the wife.
and thats £30 each time, Tin of stripper is about a tenner and I have done 6 engines with it and still have some left, and about a hours work.
Gives me more pride in the finish when I know I have done all the hard work.
Post by stationary stu on Wed Apr 20 2011, 13:10
Once painted spray with clear lacquer should help stop the paint lifting on the petrol tank. Myself I'd still go with an enamal paint rather then hammerite.
Have a look here they do lacquer and enamels
http://cgi.ebay.co.uk/2-X-500-ML-SIMONIZ-CLEAR-LACQUER-SPRAY-PAINT-/310183103062?pt=UK_Body_Shop_Supplies_Paint&hash=item48385a8a56
Post by Tony C on Wed Apr 20 2011, 20:16
Thanks for the advice.
All the different options seem to have their advantages over Hammerite, think I'll scratch my head & think about it for a day or two, thanks for the imput! Very Happy
Cheers Tony.
Tony C
Post by RAB on Wed Apr 20 2011, 20:21
Tony C wrote:All the different options seem to have their advantages over Hammerite, think I'll scratch my head & think about it for a day or two, thanks for the imput! Very Happy
Cheers Tony.
Hi Tony,
Thats the great thing about this hobby, Everyone has there own views as to the finnish.
Each to there own at the end of the day, Good luck with what ever you decide and keep us up to date with progress.
Post by Guest on Wed Apr 20 2011, 20:23
Cheers Tony.
I use this stuff from B&Q, I use there black for alot of there stuff, the Villiers base above is spraied with the Satin Super, its tip top smash, I tried Hamerite for a change and it ran and crazed like made, this stuff is easy and very forgiving, and comes in a nice range of colours, Undercoat is good to.
http://www.diy.com/diy/jsp/bq/nav.jsp?isSearch=true&fh_search=plasti+kote&x=0&y=0
Post by stationary stu on Wed Apr 20 2011, 20:26
Last time I used smooth Hammerite was just for the wheels on my van, and it looked sh1t, it looked as if I'd put it on with a catapult, thinned it down still rubbish, never again will I buy Hammerite.
Post by matt86 on Wed Apr 20 2011, 21:31
the trolley i have mde the other day is painted with hamerite and the finish is ok , but nothing to boast about .... still tempted to go over it with some black gloss with the brush , i find the cheapest best paint if from a agricultural dealer .... tractol /sparex paint is sh*t hot Very Happy
Post by Tony C on Thu Apr 21 2011, 08:08
Thanks for the link Steve.
Cheers Steve [/quote]
Think I'll give this stuff a go Steve as the budget is limited & I have loads of time on my hands cos I'm retired & it is only a little old M.K.12, thanks again everyone!
Tony C
Post by Tony C on Thu Apr 21 2011, 15:50
Update (good news)
Think I'll give this stuff a go Steve as the budget is limited & I have loads of time on my hands cos I'm retired & it is only a little old M.K.12, thanks again everyone![/quote]
Took your advice Steve went to B&Q for Plasti-Kote & it's on special offer, 3 cans for the price of two £13.98 BARGIN!!!
Very Happy Very Happy Very Happy
Tony C
Post by stationary stu on Fri Apr 22 2011, 12:33
That is a good price, nice one Tony.
