stocking up.
Page 1 of 1 • Share •
stocking up.
collected this today, its complete with good compression, a good spark. now stored in the shed waiting for its turn.
Richard.
Richard.
earlsinclare- Life Member
Re: stocking up.
very good, need a little production line going, Im waiting to see this Enfield finished
the first one
i started the lister abl first, so that i could give myself time to decide on what route to take with the enfield. rewind the coils or use battery and coil.
Richard.
Richard.
Re: stocking up.
earlsinclare wrote:i started the lister abl first, so that i could give myself time to decide on what route to take with the enfield. rewind the coils or use battery and coil.
Richard.
The ABL is a nice little unit, used to be one with the shearing gear down my end of the world, may suffer from the small lawnmower engine stigma from some crowds, even though its not one, I get it sometimes with the Norman SC
The Enfields ignition system is crap at the best of times! If its working leave it, if its dead get it out.
ignition
not realy looked at it yet in any detail. i know its all their and nothing is stuck, it could be something as simple as a good clean and re-gap. i once had a flywheel mag on an engine that several people had passed along unable to get it to run, all it needed was the magnets in the flywheel cleaned to get the rust off and away it went.
so here's wishing its simple.
richard.
richard.
up and running
the petter is now running after a retime and carb clean, it settled down and ran very smoothly.
richard.
richard.
Re: stocking up.
Nice one Richard, so will it be put away till next winter?
Stu
Stu
stationary stu- Life Member
under the bench
i've put it away under the bench so that i can concentrate on the ABL and the Enfield twin.
richard.
richard.
Re: stocking up.
earlsinclare wrote:I've put it away under the bench so that i can concentrate on the ABL and the Enfield twin.
richard.
just don't forget its there Richard...once they go under the bench,they tend to get forgotten..
regards...mike..
Re: stocking up.
richard.
just don't forget its there Richard...once they go under the bench,they tend to get forgotten..![]()
regards...mike..
the hole of no return
» HIGHLIGHT: Sailor Moon fanart by Panty and Stocking artist!
» Paper Pieced Christmas Stocking Ornament
» Basic Sock Christmas Stocking-Knit
» Complete mini Dal catalog
» Stocking suggestions
