What to run off a 24v Dynamo?
+3
DanBoy
Old Lister D
7 posters
What to run off a 24v Dynamo? Empty What to run off a 24v Dynamo?
Post by Guest Sun Jun 06 2010, 23:23
Hello,
After ideas of what i can run of a 24V dynamo?
there is + and - connections on the front, the amp meter goes up to 20 Amps,
I would like to find something like a seach/spot light or a singal lamp, but i think threse are out of my budget really.
so after a few ideas??
What to run off a 24v Dynamo? Empty Re: What to run off a 24v Dynamo?
Post by Old Lister D Tue Jun 08 2010, 23:36
How about 24v light bulbs !!!!!
Old Lister D
Old Lister D
Post by mike d Sat Jun 19 2010, 11:16
HI STEVE....
what about a 24volt cab fan for a lorry?????????...there 24volt....
regards.....mike.
Post by DanBoy Mon Jan 09 2012, 19:30
What about an amber revolving beacon. These are quite cheaply available and come in 24v or 12v. I intend to run one of these and a blue strobe (from a burglar alarm) off a 12v dynamo plus a few other LED lights.
DanBoy
DanBoy
Post by Guest Tue Jan 10 2012, 11:10
Sorry to say this but I think when your running old engines best try to keep to old lights. Steve you could easily pick up some old spot lights (vintage car type) from auto jumbles and replace the bulbs to 24 volts. I have a few 24 volt bulbs that might fit if you need a couple.
Post by DanBoy Tue Jan 10 2012, 11:44
I agree that it is nice to keep to "period" items but sometimes, thinking 'outside of the box' can be just as effective. Here's a few pics of a set-up at Klondyke last year. Certainly impressed me the way he had mixed old and new. The lamps with the sighting scopes on top are navy signal lamps with coloured lenses fitted.
What to run off a 24v Dynamo? Img00010
What to run off a 24v Dynamo? Img00011
What to run off a 24v Dynamo? Img00012
DanBoy
DanBoy
Post by Guest Tue Jan 10 2012, 11:49
I see where you coming from Dan and yes it is nice to have a bit of variation sometimes.
Post by Guest Tue Jan 10 2012, 11:54
Hello,
I have found something, a Spot light off of a Tank Very Happy, the only problem is...on the 1st run on my un-regulated dynamo the engine reved up put the current through the roof and blew my bulb, now a replacment is £25 Shocked
But here it is running on the test off my Norman SC
https://www.youtube.com/watch?v=IwVlhkGfmSA
As the set up is changing on my Scott I think I should be able to run the dynamo at 12V, then fit a car regulator in the system and convert the lamp to 12V
Post by Guest Tue Jan 10 2012, 12:07
In its New place
What to run off a 24v Dynamo? P1090097
What to run off a 24v Dynamo? DSC00755
Should be ready to test in the not to distant future, then the tidy up begins!
Post by Guest Tue Jan 10 2012, 12:10
You could maybe use one of these if you could figure out where to fit it in.
http://www.ebay.co.uk/itm/190623955016?ssPageName=STRK:MEWAX:VRI&_trksid=p3984.m1423.l2661
Post by Guest Tue Jan 10 2012, 12:34
Got to see what the Scott is kicking out off that pulley before looking into much else, off the Flywheel I was getting up to 30V
Post by Guest Wed Jan 11 2012, 10:40
Ok Steve heep us posted on how you get on.
Post by JONESEY Wed Jan 11 2012, 20:06
Plug the wife's vibrator onto it she will let you play with your engines al the time lol! lol! lol! lol! Did I really write that lol! lol! lol! lol!
Post by Guest Wed Jan 11 2012, 20:25
Thomas was born on the 9th of may 2011 she is pregnant again this one due the 4th of may, do you really think she needs such a thing lol!
Post by Foden Wed Jan 11 2012, 22:02
Skankin_giant wrote:Thomas was born on the 9th of may 2011 she is pregnant again this one due the 4th of may, do you really think she needs such a thing lol!
Well that only equates to once a year Steve, what about the other 364 days eh? Laughing
Post by Guest Wed Jan 11 2012, 22:07
She holds onto the head board and screams "Get away from me!"
Post by JONESEY Wed Jan 11 2012, 23:24
Pete you northern boys are fast excellent lol! lol! lol! lol! lol!
Post by kevjhnsn Thu Jan 12 2012, 02:52
stationary stu wrote:Sorry to say this but I think when your running old engines best try to keep to old lights. Steve you could easily pick up some old spot lights (vintage car type) from auto jumbles and replace the bulbs to 24 volts. I have a few 24 volt bulbs that might fit if you need a couple.
you will be safer with MOD british army 24v bulbs as they are made at 26-28 volts for all the bouncing arround off roading they do
last for years longer than standard 24v bulbs and pennys dearer ive had and proved to be a blessing
as a truck my father used to own was blowing bulbs ever week until he bought some army ones and lasted for 2-2 1/2 years before he sold it ,i hatted changing bulbs on that wagon about 20 screws and alien keys just to replace a bulb great in the winter doing that with all the roof water running down your neck lol
Post by Biggsy Wed Sep 05 2012, 21:37
i'm a fire systems specialist and fire systems run at 24-30v dc so bells, beacons etc could be driven
Biggsy
Biggsy
http://damned2hell.com
Post by Guest Thu Sep 06 2012, 10:17
Would be great being next to someone running bells and sirens at a rally NOT lol! lol! lol!
