Villiers Mk12 not a Mk25 "help needed"
Post by stationary stu on Thu Apr 28 2011, 18:35
I dragged my (wife's realy) Mk25 out to give it a run as it's not been started for about 18 months and she wants to paint it up. Problem is it will start but not run. Tried a different plug (one out of a running engine) and it won't even fire with that in scratch Cleaned the carb float chamber still the same. Any ideas guys Question Question Question
I've ordered a new plug but that's going to be next week before I get that, so is there anything I can try now.
Also anyone know where to get the cork washers to seal Ewart taps? I got some for pull/push tap but there the wrong size. Or do I have to pay £6 Crying or Very sad and get one from George @ Villiers parts.
Thanks in advance for your help,
Re: Villiers Mk12 not a Mk25 "help needed"
Post by RAB on Thu Apr 28 2011, 18:53
Stu have you still got old petrol in it or are you using fresh?
Have you got a good spark at the points.
As for the cork gasket, just dig deep its better to have the right thing from the start and not have to pay in the long run.
Post by stationary stu on Thu Apr 28 2011, 19:06
Not checked the points Paul, as for the petrol, yes it is a bit old but it runs all my other engines Question Question If I can tell you a bit more about the engine I bought it from Pete AKA Foden and it was running well and he did a lot of work on it (new rings). Problem is I need a few bits and everything he has is expensive so I'll have to go out and sell my body this weekend tongue tongue affraid lol! lol!
Just a bit of info I looked on fleabay for plugs before I went on to Greens plug site and it's worth checking the prices between the 2 sites and the postage is alot cheaper on ebay if your only buying a plug or 2.
Post by RAB on Thu Apr 28 2011, 19:28
My Briggs and Straton is running on last years petrol but it wasent running that great so toped it up with fresh and it runs ok now.
Thats an interesting point about the spark plugs, will keep that in mind as i need one for my Petter a.
Post by Foden on Thu Apr 28 2011, 19:36
It was always a first time starter Stu, I wonder if the flywheel has some rust on it (internally) with standing? When my mate bought it from auction it had no spark, I removed the flywheel and gave it and the coil contacts a good clean (also cleaned the points as well) and it fired straight away. I re- rang it and did the valves as well. You will lose the ignition timing by removing the flywheel, but that is easily sorted. It's a Mark 12 by the way, not a 25. Smile
Post by stationary stu on Fri Apr 29 2011, 10:41
I knew you'd done a bit of woork on it Pete, and it starts first pull then it's just as it it's running out of petrol and dies away.
Pete I''m sure you said it was a Mk25, now you got me wondering, scratch I'll have to go look after once I've woke up abit more.
Post by mike d on Fri Apr 29 2011, 12:15
stationary stu wrote:I knew you'd done a bit of work on it Pete, and it starts first pull then it's just as it it's running out of petrol and dies away.
Pete I''m sure you said it was a Mk25, now you got me wondering, scratch I'll have to go look after once I've woke up a bit more.
what you need is super Steve...hes the fella to solve this... Very Happy Very Happy Very Happy Very Happy
regards...mike...
Post by stationary stu on Fri Apr 29 2011, 14:19
I know Mike but don't think he's got round to me yet, he's too excited with that cracking new engine he's just bought.
And that Pete is trying to confuss me as to what engine it is, does he not know I'm on medication lol! lol! lol!
Post by stationary stu on Sat Apr 30 2011, 09:35
Yes it is a Mk12 sorry for the cofusion, it's my age lol! lol!
Post by stationary stu on Sat May 07 2011, 10:44
Well new plug arrived but still the same problem, starts first pull and runs for a few seconds then dies away as if it was out of fuel, but there's plenty of fuel in it, give it another pull and away she goes again. You can start it up first pull every time but it just fades away. Any suggestions before I pull the flywheel off and how easy are they timed back up?
PS It's still a Mk12 lol! lol! lol!
Post by Guest on Sat May 07 2011, 10:54
Sounds like a clogged jet, try running it with your hand over the intake.
Post by Chippie on Sat May 07 2011, 11:02
stationary stu wrote: Any suggestions before I pull the flywheel off and how easy are they timed back up?
It sounds like it is fuel starved.....blocked jet/ stuck float needle/blocked fuel line/fuel tap....
Timing is 3/16inch btdc..
Chippie
Post by stationary stu on Mon May 09 2011, 12:36
Skankin_giant wrote:Sounds like a clogged jet, try running it with your hand over the intake.
I tried leaving the choke on still the same.
Post by stationary stu on Mon May 09 2011, 12:38
Thanks think I'll pull the carb to bits before I do anything else. I have to agree it is like a fuel problem more then ignition.
Post by RAB on Mon May 09 2011, 17:31
Stu,
If you ran it on the choke it would cut out after a little while as the engine would be running to rich. Id go back to basics and see whats what before i striped the carb. Check the bolts/ nuts that hold the carb on are tight arnt they , if not they may be pulling air in and running to weak.
Post by stationary stu on Tue May 10 2011, 10:34
I think I've got another carb that will fit along the lock up so I might go get that and see if it runs with that carb. It's just strange one day it ran perfect then the next day problems, nothing in the middle Rolling Eyes Rolling Eyes
villiers carb gaskets and ewarts corks on new brass levers
Post by kevjhnsn on Sat Jul 16 2011, 04:23
hi there stu if you still struggaling for help on villiers pm me as i have a libary of villiers books and also i have now got villiers 10/2 and cm358 gaskets and parts new and old and also ewarts tap corkes and tap plungers complete ready to fit for the tread on pipe taps not the later push on pipe type and other villiers parts and engines that need parts i havent got
thanks kev
Post by stationary stu on Sat Jul 16 2011, 09:55
Cheers Kev, I have bought a book with an exploded view of the carb as I think that's where the problem is but I will bear you in mind about the other parts as I have a few small engines now and they all need sorted, just can't seem to get the time at the minute.
Post by kevjhnsn on Sat Jul 23 2011, 13:12
stationary stu wrote:Cheers Kev, I have bought a book with an exploded view of the carb as I think that's where the problem is but I will bear you in mind about the other parts as I have a few small engines now and they all need sorted, just can't seem to get the time at the minute.
hi stu
if i can help
pm me and will help were i can
thanks kev
Post by stationary stu on Wed Jul 27 2011, 12:41
Thanks for that Kev, it's been put down the queue of things to do as I must get the Wolseley finished and I need to sort out a pump for my next rally.
Post by kevjhnsn on Fri Aug 05 2011, 01:30
stationary stu wrote:Thanks for that Kev, it's been put down the queue of things to do as I must get the Wolseley finished and I need to sort out a pump for my next rally.
I HAD A FEW OF THESE APPART OVER TIME AND 2 IVE JUST REBUILT WD11 AND WLB8 SAME AGAIN IF YOU NEED ANYTHINK I MAY HAVE THE PART LEFT ON MY DONNER AND TWO DONNER MAGS FOR PARTS.
AND ALSO HAVE A MAG AND TIMING BOOK FOR WOLSELEY IF YOU DONT HAVE ONE PM AND WILL SEND MINE UP TO YOU FOR A LOANER AND ON A RETURN TO SENDER POLICY
THANKS KEV
Post by stationary stu on Fri Aug 05 2011, 09:14
Thanks Kev, I'm going to have a look at the WD11 I've just got to see what's missing from that and see what needs replacing, so I get back to you on that it might be easier to borrow one to save stripping the WD8 as I've just finishing off painting it. What might be the best way to do it is sort of hire it where as I send you some money until it's returned then if anything happens you won't be out of pocket. I think it's just the mag etc I need as Bill has a valve cover plate but need to have a good look as it's still in the van as the weather hasn't been to good and I've had a few other things to do.
Post by kevjhnsn on Fri Aug 05 2011, 19:07
stationary stu wrote:Thanks Kev, I'm going to have a look at the WD11 I've just got to see what's missing from that and see what needs replacing, so I get back to you on that it might be easier to borrow one to save stripping the WD8 as I've just finishing off painting it. What might be the best way to do it is sort of hire it where as I send you some money until it's returned then if anything happens you won't be out of pocket. I think it's just the mag etc I need as Bill has a valve cover plate but need to have a good look as it's still in the van as the weather hasn't been to good and I've had a few other things to do.
no worrys stu
the offers there if i can help you
thanks kev
Post by stationary stu on Sat Aug 06 2011, 08:44
Well managed to get a tank yesterday so need the brackets now. I'll put a quick wanted up if no use I'll try a local blacksmith to make a set.
