Now I started I cant stop
Page 3 of 5 Previous  1, 2, 3, 4, 5  Next
Re: Now I started I cant stop
Post by Guest on Sun Jul 10 2011, 10:41
Its not a Diesel engine its a Diesel starting engine, so it was started on Petrol and used to start bigger diesels, Aveling and Braford rollers had them.
Post by stationary stu on Mon Jul 11 2011, 09:51
That explains it, thanks Steve, I'm sure there'll be a few tucked in the backs of garages that's not seen the light of day for years.
Post by Guest on Mon Jul 11 2011, 11:19
Being Ex-Military alot were scrapped, there is a register of Scott engine, there is about 20 SE's on there this one having the lowest serial number, there is one for sale in Ireland at the mo.
Post by Guest on Thu Aug 11 2011, 14:27
New studs have been installed and am happy for the mo...
Post by Guest on Wed Sep 07 2011, 18:40
Got the Video up on youtube running the dynamo before I had the light, sorry about the poor quality, my phone is pants considering it has 720p video capability!
https://www.youtube.com/watch?v=-IiYAog2Q28
Post by Guest on Wed Sep 21 2011, 16:07
Quick video of how it ran at Henham (when it was running) on the sunday.
https://www.youtube.com/watch?v=QMNFWWqh9Xs
Well After blowing a bulb up at Henham, I had mix results in getting to keep going.
This is the best that I could get it, its a bit fast but any slower and it would stop, with the dynamo on it will run lovely and seemed to use less fuel then it does on idle, so will to look at getting another bulb.
And a picture of the information that I had on display
The exhaust has been turned upside down as the was a build up of oil forming in the bottom of the exhaust, it worked alot cleaner later in the day, also I picked up a brass tap, for a quid! that will be fitted onto the sump to drain it out every once and a while.
Hopefully will get a new bulb and start again!
Post by stationary stu on Thu Sep 22 2011, 15:12
Very nice display and I hope you can get your electrics sorted soon.
Post by Guest on Thu Sep 22 2011, 18:09
Should be fine, looking at getting a 24v motor to run my Wankle engine off, might make something a little intresting to watch.
Post by Guest on Thu Oct 13 2011, 14:04
Right the way forward with the Scott, the small end is in need of replacing, well a oversized gudgeon pin can be sourced, the bearing just need to be reamed out to 16mm.
While I got it apart I was thinking of doing something along the lines of this.
I was thinking about stuart turner generators and how sometimes they have the square fuel tank mounted on a board behind the engine, I recon I could make a base so the engine faces Magneto out, have the oil and fuel tank mounted on a false (maybe brick effect) wall, which can be removed for transport.
A pump of some sorts was thinking of a small centrifugal job like a small stuart one, but a smallish piston pump would do the job, which would be pumped into the cooling system kept behind the wall.
And then a exhaust system, Im currently watching a Brass stuart one on ebay, but was thinking of one of those cast iron pot ones.
Here is a quick draft:
Try and make it look a bit like a Install? any ideas, hints or tips?
Post by Guest on Fri Oct 14 2011, 09:11
Think I got it how I want it to look, I have picked up a gear pump, so its just the square wall mount tank I need really to get started, well and the small end fixing Shocked
Anyone got any advice or pictures of engine displays of this type?
Post by stationary stu on Fri Oct 14 2011, 09:36
It's just that I'm thick but I've looked at the pic and can't understand it but I'm sure you do and good luck with it and the small end.
Post by Guest on Fri Oct 14 2011, 09:49
Its going to have a false wall with the oil and petrol tank mounted on it, the water tank and exhaust will be plumbed in behind the wall, I have a small gear pump for circulating the water, which will be belt driven from the magneto drive side, Im trying to make it look like a miniature movable install, the funnel in the water feed is there to show the flow of water, I got the idea from the Petter TX at internal fire, which is i my video.
Post by Guest on Fri Oct 14 2011, 16:50
thought I better sort the problem before going and further! So I got it apart, im measuring 15.9mm at the widest part, I can get a 5 thou feeler gauge between the gudgeon pin and the bearing, I can get a 6 thou in the very edge, but though tis was because of a chamfer for getting the gudgeon pin in?
Best start saving for the way forward.....
Post by stationary stu on Sat Oct 15 2011, 09:23
Steve if you have that much wear it will be oval due to ignition putting a down ward force on to the bush. It might be worth checking the piston and see if there's any wear on that. I'm not used to small engine's but normally they are round. To re-fit the gudgeon pin to the piston, best way is put the piston into some very hot water for a few minutes to expand it the the pin should slide back in easy.
Post by Guest on Sat Oct 15 2011, 10:27
Getting the bush replaced and the piston and gudgeon pin seems fin, up and down the bush seems fine, seems to be warn on the sides.
Post by stationary stu on Sat Oct 15 2011, 14:51
Steve is this the type of fuel tank you need?
http://www.ebay.co.uk/itm/150674222728?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Post by Guest on Sat Oct 15 2011, 15:15
Nah dont want the crease in the middle, one like this
Post by stationary stu on Sun Oct 16 2011, 10:03
No problem, the tank in the pic looks home made! so you'll maybe have to do that or get one made up.
The way you've discribed the wear doesn't sound to bad so a new samll end bush should sort it.
Post by Guest on Mon Oct 17 2011, 13:21
The Circulation pump
Me being a numpty!
Hence the wanted add lol
Post by Guest on Mon Oct 17 2011, 13:22
Think im verging on a proper restoration here....:whistle:
Well looks like a got a bit more ingenuity then I gave myself credit for!
Managed to push the bush out with help from the old exhaust pipe.
There is a locating screw that got through the conrod into the bush, it didnt seem very tight, might put a bit of loctite on it when putting it back together, dont want it dropping off inside!
the ware to the bush was apparent when I could push the pin in by hand, quite easily.
Fitting the new one might be a different story!
Post by stationary stu on Tue Oct 18 2011, 09:43
Oh sh*t Steve the end of the oil pump cracking is bad news, not sure if you'll get away with just a cover or you'll need a new pump. If it was mine I think I'd fit new if nothing available repair the old one, I think these are matched units. Maybe grind a "V" along the crack then braze it, then file it down until nearly flush and finish of on a flat steel plate and emery. The outside face doesn't matter about neing flat.
To re-fit the new bush just use a press or a vice making sure it's kept level, the once it's in check for any distortion or burr on the edge. Try to heat the con. rod in boiling water first or put the bush in dry ice, I'm not sure if B&Q sell dry ice tho.
Good luck with the search/repair,
Post by Guest on Tue Oct 18 2011, 12:28
That going to be the circulation pump for the cooling system, I have been given a slab of Aluminium to mend it, should be fine!
Il work out a way for getting it back in, just got to send it off now, had a quite around the £25 mark so more then happy with that!
Post by stationary stu on Tue Oct 18 2011, 13:33
Great news that you can get it sorted.
Post by matt86 on Tue Oct 18 2011, 18:46
Steve if the plate needs to be brazed , feal free to ask im sure i could help ...
Post by Guest on Wed Oct 19 2011, 00:50
Thanks, I got some liquid metal Im going to give a shot at, the aluminum cover has not worked out well, plus the wind blew one of the bolts off my work bench so need to look for that!
