genny problem ... help
Post by matt86 on Sun May 01 2011, 18:56
i have got a generator i do not know what make or model it is but i have been told should be 110v. I am having trouble wiring it up as seem to be quite a few wires coming from it , took the end plate off and found there is 4 magnets with 3 wires going to them and then a further 2 wires going to the windings on the body .
Question is which wires do i use as positive and negative ? the wires that go to the windings do i use one as a poss then the other as a neg or what ...? Any help gratefully appreciated
Thanks , matt
Re: genny problem ... help
Post by mike d on Mon May 02 2011, 23:40
MATT....
I thought someone would be able to help you with this.....
put some photos on the forum,someone mite tell us what make it is....
regards..mike....
Post by Chippie on Tue May 03 2011, 20:13
I might be able to help.........
The issue is a little confusing when the op states that it has magnets and windings....so is it an ac gen or dc? especially when he states which is pos or neg, this would indicate its a dc machine...
if its an ac unit then I'd have thought it would have a regulator
Dynamos fall into two categories... Shunt or compound wound....
Shunt wound is where the field coils are in parallel with the armature, compound is where the field coils are split and are in series/parallel with the arm....
Does the rotor have any slip rings or does it have a commutator like a motor?
Again some fotos would help...
Chippie
Post by RAB on Tue May 03 2011, 20:25
Chippie wrote:I might be able to help.........
Thats it, im blody lost now lol! Need some pics to make head or tail of this one.
Post by matt86 on Tue May 03 2011, 21:48
its a shunt type , i have spent many hours of reserching and talking to people and it seems the field is fooked .... only 14.7 ohms for the resistance when should be alot higher than that for sure
Post by mike d on Wed May 04 2011, 10:18
matt86_wd2 wrote:its a shunt type , i have spent many hours of researching and talking to people and it seems the field is fooked .... only 14.7 ohms for the resistance when should be alot higher than that for sure
i can see this is going to cost me more money... Very Happy Very Happy Very Happy Very Happy
mike....
Post by Chippie on Wed May 04 2011, 17:53
matt86_wd2 wrote:its a shunt type , i have spent many hours of reserching and talking to people and it seems the field is fooked .... only 14.7 ohms for the resistance when should be alot higher than that for sure
Sounds like there's a short somewhere...
Do you have a multimeter/know how to use one?
Can you segregate the field windings from one another? This would help in determining which coil is goosed.......
You would have nothing to lose by attempting to rewind it....
Chippie
Post by mike d on Wed May 04 2011, 21:30
MATT...you have mail...did you get the PM i sent you??????
mike....
