Petter A1 crank seal
Post by Chippie on Mon May 02 2011, 17:46
Anyone recommend where to buy a crankshaft seal for an A1 please?
Chippie
Re: Petter A1 crank seal
Post by RAB on Tue May 03 2011, 19:58
Hi Chippie,
If you can get the seal out without to much damage to it take it to somewhere like BSL, If theres numbers on the old seal they should be able to help you out.
Ive done that with bearings in the past.
Hope that helps.
Post by Chippie on Tue May 03 2011, 20:03
Paul,
Thanks for the recommendation..I'll try not to damage it..
John
Chippie
Post by RAB on Tue May 03 2011, 20:07
No probs John,
Ive had a look in the Petter manual but they dont have part numbers, Dam shame that may have helped you as well.
Best of luck
