Duetz oil?????????????????/
Never had a diesel before, so what oil is best to use in them, i havent a clue, checked it its slightly under so need to sort it
Re: Duetz oil?????????????????/
Deisel oil :hysterical: Drain it out and borrow :hysterical: some from work the same as that old Scania uses
It is better not to use a modern multigrade in an older design of engine. The additives in modern oils do not suit the older bearing alloys. For an engine which is not doing any work it probably does not matter but if you are thinking of working it then use a straight grade high detergent oil. Shell Rotella 30 was probably one of the best. I use Exol classic HD30 for the Gardners etc which I look after. I can let you have some as I buy it by the 205l drum.
Rod
Rod
Roadster- Born to be wild
i bet the fuel consumption goes all to c**k now you have a diesel
told you to come and get that PETTER M
its cheap enough and its paraffin
dont leave it to long
mike.
mike.
JONESEY wrote:Deisel oil :hysterical: Drain it out and borrow :hysterical: some from work the same as that old Scania uses
but without the sawdust :hysterical: :hysterical: :hysterical:
iansw- A credit to the forum
