Engine tech info.
Engine tech info.
Post by stationary stu on Wed May 04 2011, 15:09
Just a thought, and all you experts out there will need to put there brains into gear and help the novice.
What I'm thinking about is a section (sticky) that will supply data for engines. I've looked though some books today and they are as clear as mud, why can't they put a section in the back with all the info you need to know.
Big end torque settings, main bearing torque settings, valve clearance, head nut torque settings, points and plug settings the list could go on. Well what I think would be a good idea is have all of these under one heading so it would only take a few minutes to look up on this site not hours going through books.
So anyone like to set the ball rolling with maybe Lister D or Wolseley settings, anything that's not relavent to the list WILL be removed.
What do you think???
Re: Engine tech info.
Post by mike d on Wed May 04 2011, 21:51
HI STU...
excellent idea mate,would be very handy for the forum members...
see you can do it if you put your mind to it.. Very Happy Very Happy Very Happy Very Happy
regards...mike...
Post by JONESEY on Wed May 04 2011, 22:18
Sounds good Stu I will Get the books out and see what I can find
Post by mike d on Wed May 04 2011, 22:53
JONESEY wrote:Sounds good Stu I will Get the books out and see what I can find
Chris don't forget your glasses mate.... Very Happy Very Happy Very Happy Very Happy
Post by stationary stu on Thu May 05 2011, 10:58
Thanks for that Chris, I'll see how many others are willing to help before I sort it out. I think it's a good idea but others are a little shy in helping or should I set it out and see if I get some response then?
