Helicoil repair
Helicoil repair
Post by Chippie on Mon May 09 2011, 19:22
Anyone any idea of the cost to have a Villiers mk10 plug hole helicoiled?
My mk10 has a partially stripped thread in the head........... pale
Chippie
Re: Helicoil repair
Post by RAB on Mon May 09 2011, 19:27
Hi There,
It will depend where you take it i would think.
I need the same done to a small Honda jenny that ive got and was quoted £20, I wondered if it would be cheeper to get a set and do it myself but just never got round to it, typical really all these jobs and no time to do owt.
Re: Helicoil repair
Post by stationary stu on Tue May 10 2011, 10:30
You can buy the helicoils and do it yourself. But by the time you buy the helicoil and the taps it could be cheaper to get someone to do it for you. Is it not just as easy to get another head?
Re: Helicoil repair
Post by Chippie on Tue May 10 2011, 16:13
I've been offered another head, just awaiting a reply from the seller.......
I might have a go at repairing it...I have a good workshop, lathe and 2 milling machines...and other stuff..
I guess I could turn up a brass insert... Smile
Chippie
Re: Helicoil repair
Post by Chippie on Sun May 15 2011, 11:30
A quick update...
I managed to buy some 20mm taps/dies and a set of M14*1.25 taps...
I can now save the head by making a brass bush, only thing is the head wil take standard plugs in placeof the 18mm version...
Not a worry I think..
Chippie
Re: Helicoil repair
