lister a dimentions ...
Post by matt86 on Sun May 29 2011, 20:57
looking to find out the width ( length of crank ) and the diameter of a flywheel . im looking to buy one but not sure if will fit down the back ... might have to have it turned around on trolley so flywheels sitting across the frame .
regards , matt
Re: lister a dimentions ...
Post by mike d on Sun May 29 2011, 22:39
MATT..
i thought you had sorted this already???
i will look in the book tomorrow mate and see if its in there for you..
regards,mike.
Post by matt86 on Sun May 29 2011, 22:53
i thought ut would fit but might be a bit of a tight squeeze , so i thought if turned engine 90 deg's would be thinner ...
Post by mike d on Sun May 29 2011, 23:52
matt86_wd2 wrote:i thought it would fit but might be a bit of a tight squeeze , so i thought if turned engine 90 deg's would be thinner ...
MATT..what you need is a ramp at the front door,in one end and out the other door..like i said before,get 2 bits of old carpet and run it on one then move the other bit and run it on that bit and so on till it out of the house,that way you wont get any oil or mud on the carpet in the house,and the wife will be well happy...
regards,mike.
Post by matt86 on Mon May 30 2011, 00:20
yeah i could do that but the alleyway is 36" wide so wider than a normal door Very Happy
Post by mike d on Mon May 30 2011, 00:27
matt86_wd2 wrote:yeah i could do that but the alleyway is 36" wide so wider than a normal door Very Happy
MATT..will check the book of words tomorrow for you...
regards,mike.
Post by mike d on Mon May 30 2011, 00:59
MATT..
I've been out in the shed and got the LISTER A/B book,the info on dimensions work out at about about 32" from end to end...
will take a picture and email it to you so you can See for yourself..
its a bit strange the way they work it,if its a wide flywheel one then it going to be 1 1/2" wider..
hope this helps you.
regards,mike.
Post by mike d on Mon May 30 2011, 13:12
MATT..
here's the photos from the book,you can work out the measurements for yourself..hope it helps you....
i know for a Lister l in a trailer,mite be something for you????
Post by matt86 on Mon May 30 2011, 20:52
that helps alot mate 1 question is cts inches ... ??
Post by mike d on Mon May 30 2011, 23:23
matt86_wd2 wrote:that helps a lot mate 1 question is cm or inches ... ??
oh bugger,i didn't get that in the picture,well i will have a look in the morning mate..
will post it for you once i know the answer,as its dark out side and raining mate..
regards,mike.
Post by stationary stu on Tue May 31 2011, 08:53
Matt just checked and cts are not inchs but this might help
http://www.onlineconversion.com/length_common.htm
Post by matt86 on Tue May 31 2011, 16:10
cant seem to find cts stu Rolling Eyes
Post by stationary stu on Tue May 31 2011, 16:50
I don't understand it either but you can now convert the cm to inchs.
Post by mike d on Mon Jun 13 2011, 00:29
sorry i didn't get back to you on this subject,but have a good excuse..
glad STU could help you..
regards,mike.
Post by matt86 on Mon Jun 13 2011, 09:07
thats ok mike these things happen mate .
and it should fit through the door fine but going to be a heavy lump to lift up and over the front and rear door frame lol!
Post by mike d on Mon Jun 13 2011, 12:41
make a ramp for it..
have it so that it goes over the top of the frame,that way there wont be any damage to the step mate..
good luck with it..
regards,mike..
Post by matt86 on Mon Jun 13 2011, 22:53
might even fir around the side as the rather over engineered trolley i made for the wolselly and h2 fitted around the side , with bags to spare
Post by mike d on Tue Jun 14 2011, 22:50
MATT...
a young man of your skill will get over it I'm sure..
good luck mate..
Post by stationary stu on Wed Jun 15 2011, 10:26
When I made the trolley for the Lister G1 I had to stop and check there was room to get it out the gate lol! lol! lol! It has about an inch n a half to spare, phew close call.
