My lister domestic pump
Post by kevin bird on Fri Jun 03 2011, 19:04
Now finished restoring my domestic pump
just got to make a tank and a trolley for it now
kevin bird
Re: My lister domestic pump
Post by matt86 on Fri Jun 03 2011, 19:08
top notch paint job there fella Smile what sort of size tank you going to use ?
Post by kevin bird on Fri Jun 03 2011, 19:22
i am very good at welding and i have got some 1.6mm steel plate so will make 1 out of that.
as for the paint job i sprayed all the individual pieces with red led primer for an undercoat and then repainted with the green as a top coat
kevin bird
Post by matt86 on Fri Jun 03 2011, 19:40
i have made a miniature drum looks like a 45gallon one but holds around 15 liters mine is made without the sign of a welder , Il take a picture and post it on here tomorrow
Post by kevin bird on Fri Jun 03 2011, 20:02
that would be nice to see
kevin bird
Post by stationary stu on Sat Jun 04 2011, 09:11
Great job Kevin, looking forward to seeing the tank made up and it all up and running.
Post by matt86 on Sat Jun 04 2011, 21:23
hello Kevin as promised a picture of the tank i have made ....
Post by kevin bird on Sat Jun 04 2011, 23:40
very nice hoping will be finished tomorrow on a trolley with a tank as i am going to a rally with it next sunday
kevin bird
Post by kevin bird on Mon Jun 06 2011, 16:33
Now finished and running on my Lister D
kevin bird
Post by stationary stu on Tue Jun 07 2011, 01:34
Looks great Kevin, and pumping very well. Way to go. Very Happy
Post by kevin bird on Tue Jun 07 2011, 16:52
Thanks,
I was very surprised as to how much pressure it had as it filled a 2.5 litre jug in 3 seconds.
May be that is just because it is on a 900 RPM engine though.
kevin bird
Post by stationary stu on Wed Jun 08 2011, 09:09
You can get reduction changing the size of the pulleys, that's one way for it not to pump as much coz if your showing it and it's a bit windy you'll have water everywhere at that rate Laughing Laughing Laughing On the good side your making the engine work for it's living ,might cost you a bit more in fuel to run over a weekend rally. A very nice set up, well done.
Post by BRASSO on Thu Jun 09 2011, 08:15
Very nice and looking really smart.
Well done.
Post by mike d on Sun Jun 12 2011, 23:07
HI KEVIN....
very nice job you've done there mate..
will look great out on the rally field..
keep it up mate..
regards,mike.
lister domestic
Post by zakyboi on Thu Aug 04 2011, 16:19
that looks beautiful! you should be proud! where did you get the paint for the pump?
zakyboi
Post by kevin bird on Sat Aug 13 2011, 07:57
I got the paint from Kenyons paint specialist in oldham.
Its a dacralite paint and they mix it to order whilst you wait
kevin bird
lister pump
Post by brooko on Tue Aug 16 2011, 22:30
very nice job thinking of giving mine a new paint job. what is the the name of the green you have used
brooko
