Stainless Steel welding.
Can anyone tell me if it's straight forward to weld stainless steel? I need to mig weld stainless steel and is it the same as steel or will I need special welding wire? I've got some brackets that are ideal for making an axle so can anyone give me some info please.
Re: Stainless Steel welding.
Done some reading up and I'm now even more confused ( if that's possable ) I use a gas-less mig welder and everything I've read is about the gas to use, so I don't know if I can weld with a gas-less welder. It looks as if I need special welding wire I've learned that it's very dangerous to inhale the fumes when welding stainless steel.
So I still need abit of help about the gas-less part of it.
Stu
Stu
never done stainless steel welding before but my brother does it on a daily basis ... im seeing him on sunday , i will ask
oh shi* i totally forgot to ask him was at wiltshire steam and vintage rally today , il ask him tomorrow if can
Not a problem Matt, I might have to have a re-think about welding the axle as I don't think it will be strong enough, so looking at plating and bolting it now.
STU..
problem is you are to far away from us Dorset boys..i know a fella that did do it but not 100% sure he still does it..
its quite expensive to do though...
regards,mike.
regards,mike.
excellent..good luck with it..
regards,mike..
regards,mike..
you need to use stainless steel wire. as far as i know, you can't do it on a gasless mig
Nate- Born to be wild
That's what I found out that I needed special gas, so I've got another idea to sort it. thanks for replying.
