another engine ariving soon :)
Post by matt86 on Wed Jun 29 2011, 21:49
Its been sat in a shed for around 30 years , and its seized soilid all it is missing is the mag , going to be a good challenge for me Very Happy
Re: another engine ariving soon :)
Post by Guest on Wed Jun 29 2011, 21:57
Good Good, not only me spending money then lol
Post by matt86 on Wed Jun 29 2011, 22:09
nope its not , this will probably be the most challenging problem i have ever taken on in all my restoring years ever worse that the fergie tractor i did , going to defiantly be a winter project lol lol! lol! lol!
Post by mike d on Wed Jun 29 2011, 23:39
MATT..a nice looking industrial LISTER A there...
shouldn't take you long to sort that out a having it running..
good luck with it mate..thanks for posting the pictures....keep us up to date Matt...
Post by stationary stu on Thu Jun 30 2011, 08:41
Nice project Matt, sure it will soon be running then the job of cleaning and painting and the trolley making. Hope it fits round the side ok Laughing Laughing
Good luck, Stu.
Post by matt86 on Thu Jun 30 2011, 17:57
it will fit even if it has to go through the house lol , and i have found out it was origionaly sold to Frank Lane & Co., Faringdon in 1943 which is where i live so will be coming back to its home town after 30 years , my plan is just to stip it down 1st and start cleaning and working my way around and rebuilding the internals as i go ....Whats peoples opinions on the best way to undersize it ? i was going to just use alot of diesel ...
Oh and im after a lucus rs1 mag if anyone has one ?
Post by matt86 on Thu Jun 30 2011, 17:59
oh and also a fuel tank as this one has no bottom at all Sad
Post by mike d on Fri Jul 01 2011, 05:34
MATT...
post a wanted add for the bits you need,you mite find it all on here..
good luck mate..
regards,mike.
Post by stationary stu on Fri Jul 01 2011, 09:26
Red diesel the best to un-seize then maybe WD40 (buy it by ther gallon a lot cheaper then the small cans, bout £25) there's always plenty of mags for sale on fleabay or ask you uncle Mike to look at GDSF i'm sure he'll find you one at a good price. Frank's tanks the best place for a new tank, they don't often come up for sale on fleabay so that might be the best bet then you know it will be a good un even tho not original. It's going to cost you big time to get the wife out the house while you bring the engine down the hall lol! lol! lol!
Good luck with it Matt,
Stu
Post by Guest on Fri Jul 01 2011, 09:45
Coke works a treat, the brown liquid not the white powder lol!
Post by stationary stu on Fri Jul 01 2011, 09:53
Skankin_giant wrote:Coke works a treat, the brown liquid not the white powder lol!
lol! lol! lol! lol! That's just your opinion Steve, alto the white powder is for when all else fails lol! lol! lol!
Post by matt86 on Fri Jul 01 2011, 12:15
lol! lol! lol! lol!
Post by matt86 on Fri Jul 01 2011, 12:20
stationary stu wrote:Red diesel the best to un-seize then maybe WD40 (buy it by ther gallon a lot cheaper then the small cans, bout £25) there's always plenty of mags for sale on fleabay or ask you uncle Mike to look at GDSF i'm sure he'll find you one at a good price. Frank's tanks the best place for a new tank, they don't often come up for sale on fleabay so that might be the best bet then you know it will be a good un even tho not original. It's going to cost you big time to get the wife out the house while you bring the engine down the hall lol! lol! lol!
Stu
i have borrowed some red diesel from work and tipped some 3 in 1 oil in it and some hydraulic oil .... that should do the job Smile does anyone have a number for franks tanks ? Im going to gdsf so il have a look around but need to find if its a anti clockwise or clockwise
Post by mike d on Fri Jul 01 2011, 22:27
MATT..
make sure you return it when you have finished with it... lol! lol! lol!
Post by matt86 on Fri Jul 01 2011, 22:55
u should know this by now mike im allways borrowing things from there lol
Post by mike d on Fri Jul 01 2011, 23:21
keep it up mate...if you can bring the puller with you i will give you £50 for it mate.. lol! lol!
regards,mike..
Post by matt86 on Fri Jul 01 2011, 23:31
haha i dont think work will be too pleased lol lol! lol!
Post by mike d on Fri Jul 01 2011, 23:35
Oh well i will have to buy one from snap on then...
thanks for your honesty Matt..
regards,mike..
Post by matt86 on Fri Jul 01 2011, 23:49
i wouldnt .... waste of money sykes and pickervant are really good ones Smile
Post by mike d on Fri Jul 01 2011, 23:51
OK thanks mate..will check it out..
Post by stationary stu on Sat Jul 02 2011, 09:36
Just an update I said recently that a gallon of WD40 was £25 well it's gone up like everything else and is now £27.50 Crying or Very sad bought some yesterday.
Post by matt86 on Sat Jul 02 2011, 18:10
no to worry stu i got some red diesel and some penetrating oil ... found a ltr of it in my old shed at parents today , il mix the two together
Post by mike d on Sat Jul 02 2011, 21:25
get some quack oil...????????????????????
Post by matt86 on Sat Jul 02 2011, 21:53
that is what it is made by swafega ..., was from when did my apprenticeship Smile
Post by matt86 on Wed Jul 27 2011, 22:10
just a quick update , the engine is now in alot of bits , have got the cylinder off after alot of struggling and soaking . After that was off found that the mains was siezed as well as the pistion in the cylinder that is now all freed of and turning nicely. the piston and con rod is out and piston needs to be soaked to free off the rings ,had the guvnor apart and the collar is sliding along the crankshaft nicely with the weights moving in and out as they should . The fuel pumps has been freed off as well and seems to be pumping bu hand when filled with diesel . even got the valves out and all been cleaned up .... pitting as normal but they will be re faced on the lathe some point . Oh and forgot to mention the big end bearing seems ok a few little marks but nothing to write home about .... its only going to power something light ish and not all day every day as was meant for i see it so it will be ok .
list of jobs to do left :
free the rings off in piston and obtain some new rings
obtain a new mag chain
make a fuel tank
clean up the cylinder and the valve seats and combustion chamber
degrease the whole engine inside and out ( be staying original condition )
obtain a working mag & fit .
After when that is all done can be assembled and try for a run but if the fuel pump leaks that will have to be re packed .
il get some pictures of it on soon ,
considering was a rusty siezed lump im doing quite well and things coming along fast as only spend a evening a week on it as it is over at my mates place .
regards matt
