Spark plugs
Spark plugs
Hi there could someone tell which is the right spark plug for my petrol lister d at the moment it has a champion d16 is the correct plug thanks
marcus- A credit to the forum
Re: Spark plugs
hi MARCUS
i was led to believe that is the right
that what my mate uses in his
mike
mike
Re: Spark plugs
thanks for that mike i just wanted confirmation thanks
Re: Spark plugs
Marcus the correct plug is an 8com but the D16 is an alternative as 8coms are difficult to get and expensive. If you looking in the reference section under the plug section or under suppliers Greens spark plug you'll get more information there.
http://www.oldengine.org/members/diesel/Plugs/stateng3.htm
https://ukengineforum.forumotion.com/suppliers-f18/plug-supplier-with-alternative-plug-reference-guide-t97.htm
Re: Spark plugs
yeah thanks got a plug today put it in and seems to be running ok ran for 2 hours and didnt cut out
Re: Spark plugs
Great news, is that the D16? Have you reset the carb. or did it run ok?
i had a d16 in my d
ran ok so must be correct one, although mine was pet/parrafin, not sure if that makes a differance, would not have thought so
