Lister D head gasket
Does anyone know the actual thickness of a Lister D copper head gasket? I would like to have a go a making one from scratch if I can get a piece of the right thickness.
Motorhead- Born to be wild
Re: Lister D head gasket
surley its cheaper and less hastle just to buy one ?
Well I figured as the price for an off-the-peg gasket is £12.99 plus p&p and a piece of copper offcut big enough to make two or three could come to a similar price I would have a go at doing my own. Buying one I would learn nothing.
ok i see your point ... sharp punches you would need , iirc its a few mm thick though
Sorry can't help as I've only one copper gasket and it looks as if it's been hit by a truck and is coming apart. All the other gaskets I've had for a D have been of the paper gasket type and I havn't anything to give an accurate measurement of one. I'd say no more then 2mm. The copper gasket I have is not just copper sheet but 2 sheets of very thin copper covering layers of gasket paper. Hope thats of help to you.
My 'D' gasket is about an 1/8 " think. It has two outer thin sheet copper with a gasket material on the outside. Good luck in making your own,
Stephen
Stephen
wortha184- I really need to post more
Thanks to all for the input. Now I have an idea what to look for.
» lister DKH head gasket
» Lister D head gasket
» lister d head gasket not sealing well?
» JAP 2A Cylinder head gasket
» Ruston Hornsby AP head gasket
