Lister D head gasket
Post by Motorhead on Tue Aug 09 2011, 17:21
Does anyone know the actual thickness of a Lister D copper head gasket? I would like to have a go a making one from scratch if I can get a piece of the right thickness.
Motorhead
Re: Lister D head gasket
Post by matt86 on Tue Aug 09 2011, 19:55
surley its cheaper and less hastle just to buy one ?
Post by Motorhead on Tue Aug 09 2011, 21:10
Well I figured as the price for an off-the-peg gasket is £12.99 plus p&p and a piece of copper offcut big enough to make two or three could come to a similar price I would have a go at doing my own. Buying one I would learn nothing.
Motorhead
Post by matt86 on Tue Aug 09 2011, 22:00
ok i see your point ... sharp punches you would need , iirc its a few mm thick though
Post by stationary stu on Wed Aug 10 2011, 09:23
Sorry can't help as I've only one copper gasket and it looks as if it's been hit by a truck and is coming apart. All the other gaskets I've had for a D have been of the paper gasket type and I havn't anything to give an accurate measurement of one. I'd say no more then 2mm. The copper gasket I have is not just copper sheet but 2 sheets of very thin copper covering layers of gasket paper. Hope thats of help to you.
Post by wortha184 on Wed Aug 10 2011, 13:47
My 'D' gasket is about an 1/8 " think. It has two outer thin sheet copper with a gasket material on the outside. Good luck in making your own,
Stephen
wortha184
I really need to post more
Post by Motorhead on Wed Aug 10 2011, 16:36
Thanks to all for the input. Now I have an idea what to look for. Smile
Motorhead
