What mag to fit a Wolseley WD2?
Post by stationary stu on Sun Aug 21 2011, 10:50
Can anyone have a look at there own WD2 and confirm the number on the mag that I need.
The numbers I have that fit are A906Z or a A906BZ can you let me know if these are the correct mag I need and is there anyothers that will fit without changing anything?
Also is there a way to check that an impulse mag is working or is it just fasten it in the vice and turn it till the impulse kicks in and how do I check it's rotation. Reason I'm asking I have an old mag and want to see if it works ok then I can swap some parts to a damaged one that's for sale on ebay.
While I'm asking are all WD the same rotation? It's something I've never thought about till now.
Thanks in adavance for your help,
Re: What mag to fit a Wolseley WD2?
Post by Guest on Sun Aug 21 2011, 14:02
Impluse will only click going one way, You can hold onto them and runt them by hand and still get a spark.
You can get reverse rotations WDII's
Post by matt86 on Sun Aug 21 2011, 14:04
shame i sold mine could of had a look .... ask mike he would be able to check his one
Post by stationary stu on Mon Aug 22 2011, 11:45
Thanks for the info Steve.
I've got to phone Mike in the next few days so I'll get him to check his WD2.
wd2 mag
Post by kernowjohn on Mon Aug 22 2011, 13:07
the mag on my wd2 reads a906bz
hope this helps
regards john
kernowjohn
Post by RAB on Mon Aug 22 2011, 16:08
Stu,
This is the mag types that i have listed for the WD11 engine, if i find anything else then il let you know.
A 906Z A 906BZ
Paul. scratch
Post by stationary stu on Tue Aug 23 2011, 12:03
Same numbers as I have, thanks for the help guys. Now I wonder what the difference is between the Z and the BZ at the end Question Question I wonder if it as Steve says it's a reverse rotation Exclamation
Post by gavin b on Tue Aug 23 2011, 21:51
Also check the size of the back plate,by this I mean the fixing bolt holes are wider on a Wolsey than a Petter,as I once tried to fit a Petter magneto to a Wolsey but it would not go down the two fixing threads.
Hope this helps.
gavin b
Post by stationary stu on Wed Aug 24 2011, 09:12
Gavin could the holes be enlarged?
Post by mike d on Wed Aug 24 2011, 12:00
i have the very thing you need mate...
call me..
Post by stationary stu on Wed Aug 24 2011, 17:56
Very Happy Very Happy I'll phone you later this week mate.
Post by mike d on Wed Aug 24 2011, 21:44
hi Stu..
look forward to the call...
mike..
Post by stationary stu on Thu Aug 25 2011, 08:45
Oh goodie I'll reverse the charges lol! lol! lol!
Post by mike d on Sat Aug 27 2011, 02:43
Stu..
it was nice to here from you today mate...
but we never spoke about the mag...or have you sorted it now??????????
regards,mike....
Post by stationary stu on Sat Aug 27 2011, 09:22
Great to hear from you but there was no need to hang up when I reversed the charges. lol! lol! lol!
I forgot all about the mag. Y still need one so I'll call you once your back from GDSF.
Stu
Post by mike d on Sat Aug 27 2011, 10:34
ok Stu..im off on Monday,but the MRS will be here..
not that she will be able to help with a mag..... lol! lol!
Post by RAB on Sat Aug 27 2011, 13:14
stationary stu wrote:Same numbers as I have, thanks for the help guys. Now I wonder what the difference is between the Z and the BZ at the end Question Question I wonder if it as Steve says it's a reverse rotation Exclamation
Surley if it was a Reverse rotation it would have 'R' at the end
Post by stationary stu on Sun Aug 28 2011, 11:05
Don't know Paul that's what I 'm trying to work out. I know it's an easy change to convert the Lucas mags to change it's rotation but not sure on a Wico with it have the impulse on it.
I think a great bloke called Mike king might have one to fit so fingers crossed.
Post by mike d on Mon Aug 29 2011, 04:06
STU....
call me next week and i will sort one out for you mate.....
it will be fine,stop flapping you silly old feller.... lol! lol!
Post by stationary stu on Mon Aug 29 2011, 09:16
lol! lol! lol! lol!
Cheers mate, have a good time at Dorset and don't spend too much Wink
