work comenced today on EV1
Page 1 of 3
Page 1 of 3 • 1, 2, 3
I decided to start stripping the ev1 apart mainly to give me something to do but the plan is a full cosmetic restoration as it runs fine and inspected the mains and they look in good condition too and plenty of suction. So just a cosmetic one this time .
Started to strip it apart just need to mark the ignition timing so i know where it goes back , cant seem to find the timing marks on the flywheels so il make some on the crank sprocket myself . and then i can get the grinder out with the wire brush head and the sanding disc's and hopefully get some red oxide applied to the block by tomorrow.
there is a fibre seal on each end of the mains where would i get some material like this from ?
regards , matt
regards , matt
Re: work comenced today on EV1
a few more pictures , got the block and sump stripped and in red oxide now ...
Getting on well Matt, looks to be an easy restore if everything is in good working order.
stationary stu wrote:Getting on well Matt, looks to be an easy restore if everything is in good working order.
yeah it will be stu , regarding the internals its all ok with no excessive wear . the only thing i need to get is a original exhaust and a fuel tank
always amazes me how much different things look with a coat of paint
looking good so far
looking good so far
hob- Life Member
got some green on it today as well but didnt get any pictures of it , Should have the wood cut for the trolley tomorrow
That fibre seal looks like normal 1/2 gland packing Matt, although I am not sure.
Should be able to get gland packing in any place that sells pump spares.
BRASSO- Life Member
i have got some 1/2" and 1/4" gland packing , i will use some of that
a few pictures of the engine been painted , have not started on any other parts from the sump and block
looking good Matt..keep up the good work mate..
no hanging around is there ... ? how was the rally mate ?
assembled the timber together for the trolley today just needs sanding down as you may notice the glue stains :embarrassed: Then oiling and the axles made . then i can start by assembling the sump and the block onto the trolley .:yahoo: ...surpose next step would be to start cleaning down some other parts to paint ....
a few pictures :
decided to try and do the joints with a old style teqnique with pins , there is 4 screws only to hold the axles spacers on , but will not be seen .
regards , matt
a few pictures :
regards , matt
hi there matt
looking good so far
thought you might of painted it one of the other bamford colours
keep it up the work i meant
looking good so far
i'm making a trolley for mine at the moment, how do you fix your axles?
hob- Life Member
kevjhnsn wrote:hi there matt
looking good so far
its not a bamford colour lol its alister green shhhhh
there will be a flat peice of bar on each corner with the axel welded across it then bolted . once it is made i will take pics for you .... follow the experts
matt86_wd2 wrote:kevjhnsn wrote:hi there matt
looking good so far
to me paint is paint they last better with a good coat of it on
well apart from emullsions they dont work so good on metals , they tend to go a rusty colour and fast
my neighbour painted a home made trailer with it looked good for a week in the summer , then it rained half washed onto his tarmac drive , the next day the rest wwas rusty brown white emmulsion , his drive is still with a 2 ft wide grey snake down the middle 2 years later
i find that cast wheels look better with a satin or semi gloss topcoat car spray type mine still rust free 2 years on the cast seams to breath better through it than a high gloss topcoat THATS MY OPINION ANYWAY
THANKS KEV
Coming along well Matt, you might get a rally out of it this year the rate your working I do like the no screw trolley, makes it look a better job and I don't think many will put there heads under it to see the screws in the axle
Keep up the good work.
stu they wont be able to see them once the axle is on there
probably wont do a rally this year with it
Matt try and get a date to aim at it gives you a bit of get up n go to get it finished then come and finish mine
i havent done much on it this week really as there is all the other jobs around the house that have priority etc ... went and picked up dome tung oil , so next need to sand the base down .
ipdate ..... sanded the trolley down and now i have put 2 coats of finishing oil on just waiting till morning and can wipe down with some scotchbrite and then apply the top coats .
went to pick up some round bar for the axels 30 mm but will be having the ends turned down to 22mm to fit in the wheels i have got with .5 of a mm clearance . just need to get that done and plates welded on , wheels need to be cleaned and painted and then assembled so its all go at the moment .
watching this with interest Matt, i nearly bought one of those as my second engine..........ended up with a Lister D instead
looking good so far
looking good so far
hob- Life Member
Nice to see your making progress again Matt.
Neville I'd love a Bamford but there a bloody heavy engine to be pulling about, I know everyman and his dog has a D, at least you'll not hurt yourself as much moving it around. Only thing to do is trailer mount it when your the wrong side of 35
» Work on the JAP 2A
» Tandem Lister D Restoration
» 1924 wade drag saw.
» a trip to bradford.
» Kubota diesel KND3
Page 1 of 3
