spark plug
spark plug
Post by doris on Thu Sep 08 2011, 18:10
hello i wonder if anybody would know why my sparke plug on my lister a is sutting up i have just fitted a new carb
doris
Re: spark plug
Post by Guest on Thu Sep 08 2011, 19:15
Could be to rich or the wrong heat range plug, Champion 8com or D16 is a good plug for a D or a Lodge BBL.
A Little load may help it as well.
Re: spark plug
Post by matt86 on Thu Sep 08 2011, 20:39
correct there steve ,my d doesn't like ruining for long off load .
Re: spark plug
Post by mike d on Thu Sep 08 2011, 20:51
hi doris..
my mate has the same problem with his Lister D...
i borrowed it for 3 shows,i belted a small corn mill to it and it didn't miss a beet.
you mite try turning the mixture back,once you have it running turn the mixture down slowly..
if this doesn't work try putting a load on it,you could get a 12volt dynamo and belt it up..
this should sort it..
please keep us posted on how you get on...
regards..mike.
Re: spark plug
Post by stationary stu on Fri Sep 09 2011, 09:24
Shame he's asking about a Lister A guys lol! lol! lol!
Sounds as if your running a bit rich.
What number plug is fitted?
If you try this site it will give you alternatives to try, so look for a hotter plug.
http://www.gsparkplug.com/shop/champion-8com.html
Re: spark plug
Post by jay on Fri Sep 09 2011, 09:29
check as well the return fuel pipe isnt blocked as that will make the carb flood and the excess fuel will go in the engine making it run very rich(the black smoke will be a big clue if this is happening..
jay
Re: spark plug
Post by BRASSO on Fri Sep 09 2011, 09:35
Should be running a Lister A on a Lodge BBL plug. Also as everyone else has said sounds like its running rich. Turn the needle to about a quater turn or just over to start up, and then once warm turn the needle down a little very slowly bit by bit. If the engine sounds like its starving just click the needle back one notch. As Mike said it will run much better with a bit of load on as well.
Re: spark plug
Post by BRASSO on Fri Sep 09 2011, 09:42
Also make sure after start up that you adjust the carb.
Carb more open it means less fuel and more air, carb more closed it means more fuel and less air.
I always close my carb about halfway when starting up, and then once started and warm, and also with a load on I open the carb fully.
Re: spark plug
Post by jay on Fri Sep 09 2011, 11:16
as brasso say my lister A will only run with carb air bit open about halfway otherwise it will just stop and fuel control about 1/2 turn open once running but as each valve is diffrent on each engine best way is once running turn down fuel control until it starts to slow then open it up a small amount thats how it should be to run ok and if a load is put on the flywheel then the throttle will open up and engine should pick up cleanly if loads of black smoke its to rich if it just open throttle and stops mixture is to weak only way is to run the engine and keep trying until you find its about right..dont forget a warm day will need a richer mixture than a cold day
jay
Re: spark plug
Post by mike d on Mon Sep 12 2011, 21:57
stationary stu wrote:Shame he's asking about a Lister A guys lol! lol! lol!
Stu..
i knew that,i was giving him a similar scenario you old fool... lol! lol! lol! lol!
regards,mike..
Re: spark plug
Post by stationary stu on Tue Sep 13 2011, 10:54
Stu..
regards,mike..
Yeah Yeah, you've lost the plot you silly old goat and your trying to get out of it lol! lol! lol!
Re: spark plug
Post by mike d on Wed Sep 14 2011, 00:20
yea yea ive lost the plot !!!..i think you should look in the mirror mate and the answer will be staring you in the face...
old goat??? well ive been called some things in my life time but old goat ???? well i never..
you can fall out with people on here very quickly..... lol! lol! lol! lol! you old coffin dodger.... lol! lol! lol!
regards,mike..
Re: spark plug
