Lister A drain tap thread help !
Post by matt86 on Sat Dec 10 2011, 20:53
My lister A has a stripped thread in the hopper , tried a few things and do not now what else i could do .
i have tried lots of PTFE tape , a ring of solder behind the tap shoulder , copper washers etc but i can just get a bite but will not tighten up !
There is not much metal to drill out and recut for a bigger tap . The size is currently 3/8 bsp .
Any idea on what i could do next would be greatly appreciated .
regards , matt
Re: Lister A drain tap thread help !
Post by Villiers on Sat Dec 10 2011, 22:55
see here...
http://www.stationary-engine.net/forum/showthread.php?t=25032
Post by matt86 on Sat Dec 10 2011, 23:10
Villiers wrote:see here...
you do realise that is me as well asking that question on fozzers do you ?
Thanks for the help i have ordered a 1/2" tap and the correct pilot drill . A 1/2" to 3/8" bush as well . once i got all those bits i will be able to sort out that bodge once and for all !
I used to be able to screw a tap in there ok , but had to pack it with a ring of solder . Today i finished assembling the engine again and when i went to screw the tap in , it just wouldn't play ball !
Post by JONESEY on Sun Dec 11 2011, 08:06
Matt, I missed the post I have taps and dies here you could have borrowed and the brass taps to match let me now if I can help will sort your fuel neck out later
Post by stationary stu on Sun Dec 11 2011, 10:49
Matt I've used plastic metal in the past and it worked well no leaks and strong enough to use the tap without it comming off in your hand. I know it's not what I wanted, as I wanted to drill/re-tap but the hole was going to be to big to try and hold a drill level and get a perfect round hole to tap.
tap size
Post by ray on Sun May 13 2012, 18:20
my lister A junior has 1 inch bsp thread can get brass taps to this size so will have to open youres up to this.
ray
I really need to post more
Post by mike d on Sun May 13 2012, 23:03
matt there a head on eBay for sale..see if the fellers got anything that mite help you...
Post by stationary stu on Mon May 14 2012, 11:06
mike d wrote:matt there a head on eBay for sale..see if the fellers got anything that mite help you...
No body looking for a head? lol! lol! lol! lol! lol!
