Very Old Saw Bench - the restoration has begun.
+2
bluewater1150
6 posters
I got this in bits from the forestry at Kielder - the rebuild has begun. I've started with the 'moving parts' - the theory being get everything running smoothly 'away from the table' and then re-assemble the whole saw bench table.
The first photo is of the removed belt pulley guide assembly - with no guide and a seized slider.
The 2nd is of the saw blade casing and drive shaft - as removed from underneath the main table.
3rd is the casing with drive shaft still in place and the two pulleys removed, the inner one was running free and the outer one was solid on the shaft - completely
the reverse of what it should be.
4th is the casing with the shaft removed - it took a gallon of petrol to clean the old 'grease' out - no bearings on this shaft/casing, but a great fit with v.little play.
next is the belt pulley guide, the slider is now all freed off with 2 x new guides c/o the local Blacksmith
Last is the shaft refitted back into the fresh grease packed casing and both pulleys fitted, loose and drive working as they should - the drive closest to the table and support casing, the loose pulley outboard of everything.
Next thing is to get the cast saw bench table home to see what is next in the re-build.!!
Elliot
Elliot
bluewater1150- Expert
Re: Very Old Saw Bench - the restoration has begun.
smashing work there Elliot keep it up !
Looking good Elliot coming along nicely, keep us posted,
ian webb- Life Member
Looking good already , keep us posted, thanks for posting photos
Good work Elliot. Hope it all goes together smoothly.
DanBoy
DanBoy
DanBoy- Life Member
Good work Elliot, post some pics of the table when you get it home.
looking good feller,keep it up and keep the photos coming mate..
» Wolseley WD2 restoration
» WD8 Restoration, help please
» Conord F0 Restoration
» First Restoration :)
» wolsley wd
» wolsley wd
