help..my wolseley WD2 pumps fuel out of the carb....
Page 2 of 2 Previous  1, 2
Re: help..my wolseley WD2 pumps fuel out of the carb....
Post by kevjhnsn on Sun Feb 19 2012, 02:17
well i cant think were it goes but its got to have one for pressure changes every up and down of the piston
was woundering if it went into the carb
he says fitted new rings due to lack of compression earlyer today
woundered if rings are not sealing correctly to bore and compression being dropped into crankcase and blowing back through carb
no or low compression due to new rings does happen
my farther was agri engineer specialist for leyland david brown and fiat
and after some rebuilds they had to put tractor on a dyno tester for up to 20 hrs just to get the power back into some of the cylinders
and also on some new engines from fiat
Post by Foden on Sun Feb 19 2012, 09:43
WD's breathe through the carburettor base, where the flash arrestor gauze is if it still has one, I would try another plug Mike before I went any further. There was one at Lincoln last year doing the same, the poor guy had the carb to pieces and the magneto and I suggested the plug but he said that it was a new one and sparked ok. After about an hour I took him a plug across, fitted it and away it went, so even a new NGK was absolutely useless but sparked fine in the fresh air. The other thing with the WD's and PT's is that if they dont fire straight away they soon flood, and they will never fire then. I tend to just turn the fuel on just enough to fill the float chamber and then start it, turning the tap back on when it picks speed up.
Post by stationary stu on Sun Feb 19 2012, 10:55
Mike you are turning it in the right direction? Stupid question but it has been known.
Post by Foden on Sun Feb 19 2012, 12:29
stationary stu wrote:Mike you are turning it in the right direction? Stupid question but it has been known.
A good point! A lot were reverse rotation, but I assumed that Mike had run it in the past?
Post by DanBoy on Sun Feb 19 2012, 15:19
I think that what's needed here is some sagely advice.
"Mike, give up on it. It'll break you if you keep trying. Sell it to me for a pittance whilst you still have your sanity. You'll never have to worry about it again" lol! lol! lol!
DanBoy
DanBoy
Post by kevjhnsn on Sun Feb 19 2012, 19:03
danboy
ive aready tryed that hand with him
but to a no win end
WD2 fuel problem
Post by bencam43 on Sun Feb 19 2012, 19:45
Mike, If you have checked timing, spark and carb,there is not much else left, is there plenty compression?., check inlet valve clearance if its too tight it could csuse it to blow back through the carb
Bill
bencam43
Post by mike d on Sun Feb 19 2012, 21:23
many thanks gentlemen,ive read all the answers and ive decided to leave it till im sorted with the shed...
then im going to strip it down again and start again.....i don't get it as ive done 2 more previously with no problem...
it was all running before with poor compression,i am turning it the right way,ive changed the plug 4 times and tested them in the other WD and work fine in there...ive timed it the way i always do,and the book as well...
im not going to scrap it,but it gets you like that sometimes..im going through a tough time at the mo,so its better off leaving it till another day.....
once again thanks for all the help,its much appreciated indeed....
kind regards to all ...
mike
Post by stationary stu on Mon Feb 20 2012, 12:07
Mike sometimes you just have to start again, it will probably be something small you've over looked.
Post by mike d on Mon Feb 20 2012, 22:18
that's what im going to do i think..much better idea as well,once ive had shed and drive sorted..
Post by billypurves on Tue Feb 21 2012, 13:01
Hi Mike, Is this a nice fresh painted engine? If it is you may not be getting a decent earth through the paint on the mag.
You will get a good spark on the impulse.
billypurves
Post by mike d on Tue Feb 21 2012, 15:22
hello stranger..lol.lol..
thanks for the reply mate,i will take a look at it once the shed is sorted..
hopefully i can sort it..
Post by matt86 on Tue Feb 21 2012, 17:56
A Older experienced engine man like you should be able to get it sorted easy enough ... you have to check everything with a fine tooth comb Smile
Knowing you its going to be something daft lol! lol! lol!
Post by mike d on Tue Feb 21 2012, 21:56
matt86_wd2 wrote:A Older experienced engine man like you should be able to get it sorted easy enough ... you have to check everything with a fine tooth comb Smile
i was doing it in my little bt shed and as you know there wasn't a lot of room..
and i was stressing about moving house as well...i will do it but will wait till the sheds done and the concrete is finished
stress free then mate...
Post by matt86 on Tue Feb 21 2012, 22:05
exactly mate , sit back and relax and have a cuppa at your own pace
Post by mike d on Tue Feb 21 2012, 22:23
i will put it up on the lift and sit and take my time,its just a matter of taking my time..
Post by stationary stu on Wed Feb 22 2012, 10:47
If it takes you as long as it has taken me to do my WD8 god help us, I've been on with it 18 months now Laughing Laughing
Post by mike d on Wed Feb 22 2012, 20:22
Stu..im slow but not much faster than you.. Embarassed Embarassed Embarassed
Post by JONESEY on Wed Feb 22 2012, 23:53
Slow but sure lol! lol!
Post by stationary stu on Thu Feb 23 2012, 11:29
Ok felt guilty yesterday so did a bit more, if I get my finger out II might take it to a rally in April Laughing Laughing not saying which year.
Post by mike d on Thu Feb 23 2012, 19:26
slow and sure wins the race..well that's my excuse....
Post by stationary stu on Fri Feb 24 2012, 11:44
Mine too now Mike lol
Post by mike d on Sat Feb 25 2012, 09:29
stationary stu wrote:Mine too now Mike lol
Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed Embarassed
Post by stationary stu on Sat Feb 25 2012, 12:15
lol! lol! lol!
