unknow pump
unknow pump
Post by Diddy on Sat Feb 18 2012, 23:15
got this little brass pump.i dont know who made it.but its nice.
thinking of puting it to run with my stuart turner engine.
Re: unknow pump
Post by matt86 on Sat Feb 18 2012, 23:26
Dave what is the part from the tap outwards about ....? i cant seem to figure out what it would do .... as i can see its a centrifugal impeller pump with inlet and outlet either side of body . but thats it . pretty basic to be honest .
Re: unknow pump
Post by Diddy on Sat Feb 18 2012, 23:29
that bit on the end was a large bullet head.that got milled out then drilled to take the bit of pipe.i stuck in on a 5hp petter at 2000rpm i got bloody soked.
Re: unknow pump
Post by hob on Sat Feb 18 2012, 23:41
i thought maybe it was for priming?
Re: unknow pump
Post by kevjhnsn on Sat Feb 18 2012, 23:48
i agree it looks like you fill with water though it then turn the tap of and then run the pump
pre wetted to start the suction off
like on my large centrifugal pump i run with MY LISTER A
Re: unknow pump
Post by matt86 on Sat Feb 18 2012, 23:50
hob wrote:i thought maybe it was for priming?
thats quite plausible ... i thought it might be a drain but not with the cup part on it .
Re: unknow pump
Post by Diddy on Sat Feb 18 2012, 23:53
thats wot i did with that end used it for primeing.
Re: unknow pump
Post by kevjhnsn on Sun Feb 19 2012, 01:01
so its best used with pipes fitted then that are facing away from you then dave lol
sounds like its got good output flow then ???
sounds like it will get rid of unwanted pets and children then from a distance lol
Re: unknow pump
Post by stationary stu on Sun Feb 19 2012, 11:37
Very nice looking pump shame about the alloy pulley, that will shine up nice for the rally field.
Re: unknow pump
Post by DanBoy on Sun Feb 19 2012, 15:23
Ooooh, look at all that brass. I could spend hours with my Dremmel polisher on that....... Cool
DanBoy
Re: unknow pump
Post by Diddy on Mon Feb 20 2012, 00:09
a up dans got a fetish..lol.is wot it could do with is rubbing down to take all the pitting out the body make it smooth.well im not going to use it now as iv got another idea for st engine.it will be all on a very little trollyhidden water tank think the fuel tank mite be hidden as well apart from the fuel cap.
Re: unknow pump
Post by kevjhnsn on Mon Feb 20 2012, 01:12
forward thinking on the trolley design and going for a steamline finish
i like it mate sounds a good idea to me
cant wait for the photos to start rolling in of the stuart pumping set up trolley
good look
Re: unknow pump
